Which random orbital should I get?
Hello everyone!
I've decided to get a random orbital because of the time it would save adn for the better results I would see. My question to you is this, which model/brand should I get? I see Griot's sells one as does Meguiar's. Any thoughts?
Thanks in advance for your input.
Jon
Jon
Originally Posted by 199
Porter Cable, all the pro use it i don't know which model
which random orbital should I get?
Thats why I mentioned Craftsman--nice unit to start with and you can always get another model later after you get some experience. Meguire's always has some good tips for buffer use and Autopia should have some good tips too. You can get a pricier buffer later but I'd suggest getting an entry level unit and make sure its something you are comfortable with using--nothing worse than getting something with more power than you need and not knowing how to properly use it...definately a recipe for disaster
I'm with TexaStang, get the Porter Cable 7424. I have one and have had great results with it. Here is an article on it-
http://www.guidetodetailing.com/arti...p?articleId=47 vbmenu_register("postmenu_657860", true);
