Into / clay bar question
Anytime Max... let me know if you have further questions. I will try to answer when I can. I try to balance being a husband, father or 2, engineer, detailer, and everything else hard to do. Forgive me.
Indeed.
Whoever made that post needs to stop spreading misinformation. Don't post things you don't understand. It infuriates me that now, someone may drop his clay bar on a "swept floor" and reuse it. I mean come on. It's common sense. Unless your floor is a surgical ceramic tile, well heck, even then I'd throw it away. Lol.
I clayed the very next day.
I clayed my Boss a little over a week after I got it (Meguiar's kit).....I pretty much did the exact thing that's been recommended in this thread but I found it to be gliding very smoothly at all times and on every panel. I was under the impression that I would feel some resistance and even some "dirt" or substance on the clay bar, but it was extremely clean after the whole car was done. I then wiped down with a nice MF, applied a coat of Meguiar's Gold and then their detail spray after that........and to be honest, it looks exactly the same as when I just washed and waxed it. I wasn't sure I did it right at first but after reading this, I apparently did. I'm just not seeing the visual benefit of the clay bar. It's Grabber Blue if that makes any difference.
Clay bars are going the way of the 8 track tape.
http://www.autopia-carcare.com/surfa...wel-combo.html
http://www.nanoskinusa.com/_e/AUTOSC...CRUB_6_Pad.htm
I buy my clay bars from Finishmaster. I buy either Meguiar's blue, Schlegel Gray Ghost or CAR products ptofessional grade clay bars. The first thing I do when I open the package it to cut the bar into eighths. I use a small section at a time, kneading and folding it frequently. When it gets to the point where it can't be used on paint anymore, I use it for glass or to break down stubborn brake dust on wheels.
If I drop a piece, I just toss it and grab another.
I've been using an absorber type towel that comes in a tube to dry my car. I never liked the skin shammy. You couldn't pay me to use a bath towel.
Is the micro fiber towel better for drying than the absorber?
#20 is an AWESOME product and so easy to use! I use it for customer cars quite often. You could try topping it with D156 or it's consumer equivalent, Ultimate Quik Wax, for a deeper wet look. Either way, I would suggest UQW after maintenance washes to help boost the #20
you can clay it as soon as you drive it home. Do it in the garage if possible after sweeping the floor so if you drop the clay it should be ok. You can clay a bigger section than 2x2 and still be ok as long as its lubed up well. Tell the dealership not to wash, wax or buff your car and if you don't want the front plate mounted tellem not to mess with the front bumper either.
Congrats on the new ride and welcome to the sitte.
If you drop the clay... discard it! Even the best swept floor will have microscopic particels of dirt on it, which will scratch the paintwork.
You know when clay is doing something because you can hear it. There's a distinctive sound (a bit scary the first time you hear it -- sound like you are scratching the crap out of the paint) and resistance -- and the clay will get visibly dirty.
