Car Detailing 101
#181
A Man Just Needs Some....
Originally Posted by FromZto5
Thanks bill... I appreciate the kind words. I'm just a regular dude with an insane passion for detailing. Lol
holy cow... I dunno, maybe it's just years of experience, but I can fully wax a car in under 15 mins... And no using tape, and no getting accidental wax or sealant on the trim.... Hmmmmm
#182
Originally Posted by DaGonz
The next time you polish and wax, take a few minutes and tape off all of the trim using either 3M painters tape or the automotive version of it... it saves hours of work.
Posted by Zto5
I do tape off moldings and trim when I am doing a full paint cleaning and detailing, mostly as a precaution when polishing with either PC (my polisher of choice 99.99% of the time or the rotary (rarely used).
#184
Zto5.. while you and I have perfected our wax application techniques, many owners just slather it on and get it on the trim, etc.
#185
I'd never taken the time to tape off a car before waxing, until the last time I waxed my GT because I got worried about wax on all the black plastic trim. So I did that, but couldn't avoid some bits of tape sticky residue in a few different places - I was using the regular ol' blue painter's tape. Should I use something different next time? Light clay bar work took car of the residue.
#186
#187
You are right gonz... I keep forgetting that this is not the autogeek or autopia forums
You have residue with blue painters? Hmmm that's the reason why we use blue painters, to avoid any residue. I use it all the time when correcting paint. Tape to cover trim, plastic, glass, etc... Even when separating paint sections. What brand you using? Maybe it's old?
#188
Alright pros. I happen to have a brand new bottle of 3M ultra fine polish. Have you guys used this with a DA polisher? If so what pad and is it worth using. It was a freebie so I won't use it if it's no good.
#189
How bad are the swirls and defects in the paint and does the bottle say what level scratches it will remove? I'm assuming it's lea aggressive since it says ultra fine.
Since my car is new, I use a fine polish and the least aggressive polishing pad
#190
The normal 3M stuff and it wasn't too old - it was mostly at the seams where I was overlapping to go around curves and such. Not sure why it happened.
#192
#193
Detailing Guru
Use it and love it myself on a DA. Blue pad on ultrasoft clear's, otherwise black will probably do fine.
#194
#195
At times, you can mix and match a compound with a soft foam pad or a fine polish with a coarse pad... Just depends on type of polish, hardness of clear coat, etc.
#196
Detailing Guru
Al, if the polish is a fine or ultra fine polish, I would use a soft foam pad. From your selection, looks like gray. However, note that fine polishes and soft pad are to be used for jeweling, in other words, once defects have been removed. Essentially for this stage, you are restoring the luster back in it after correcting/compounding.
In the end you'll just have to try some things. I know people don't like hearing how they'll have to do any type of experimenting on their car, but when you do it in a safe an sensible manner; you're fine.
Imagine you get a brand new lawn mower and need to figure out what height to set the blades. You certainly wouldn't like the idea of having it too low and scalping your lawn, so you set it high (least aggressive) and begin to lower it from there.
Use that same mentality on your car and you'll not only treat her well and keep her from damage, but you'll learn a bit about her finish, the products/pads you have and how you can achieve the desired result along the way.
#197
Bingo!
hehe.
Marc, for the record, if we lived in the same town, you and I should have been partners opening our own detailing shop. I love being an engineer/mgr, but my passion is detailing If only it paid as good
#198
Detailing Guru
Marc... that is a very good metaphor. I like it. I wonder if I could use that same analogy with my son's haircuts? (he's 3). Start with the least cut electric razor, see how he likes it, then go down from there? hehe... sorry, parent mode kicking in.
hehe.
hehe.
#199
