Best Method for Removing Water-Spots
#41
We don't have hard water here, but I keep a good coat of wax on my car and I have very little water to dry off when I wash it. Everything just slides off except for the glass and the really flat areas. I would suggest using a coat of Meguiar's #2 Polish followed by a good coat of Mequiar's Gold Class Wax and finishing up with a final coat of Meguiar's Showcar Glaze.
The wax on top of the glaze protects and gives depth to the shine but evaporates within a few weeks. Either will help shed water better than nothing.
Have you discovered a secret in using these products in this order, or is it a M.B. exclusive?
#42
Most people spray their car to rinse the soap off, then dry with a couple microfiber towels. That's okay, but the spraying makes a lot of droplets all over the place! I suggest using a nozzle that can be adjusted to flood water in a slow steady stream, or just take the nozzle off the hose. Turn the water on (about 1/4 or less) so it comes out in a weak stream. Start rinsing at the roof holding the hose fairly close to the surface and pour the water on moving slowly from one edge to the other. Continue over the hood and trunk lid, then down the sides, rear and front. You can even do the wheels this way.
Antigini-GT/CS
10/5/15 09:43 AM
9/10/15 12:44 PM
