The 'ask any detailing question' thread
I have this 2012 Kona Blue mustang in which I want to wetsand it to remove as much orange peel effect as possible. Now my question is with this new Tri-Coat stuff they are doing on the paint process, do I have to do any particular things differently when approaching this Tri-Coat wetsand?
Any information is really helpful, this is my first attempt and my close friend who is a professional detailer will be giving guidance, I just want to make sure I have the nuisances worked out in my head.
In no way do I recommend this. It's very very very time consuming, risky, and I don't know anything of your skills / knowledge / abilities to say you'll be able to pull this off and maintain it correctly.
This isn't a job that you experiment with, and any mistake can be quite costly.
Personally id use a good DA polisher and an abrasive polish, a couple coats and passes over the car and youll achieve great results especially with the dark kona color. Top this off with a couple thin coats of wax or sealant and youll be stunned at the results.
If youre still not satisfied then wet sanding is still an option. This way youll still have plenty clear to mess with in the future
Draxxus: one option you may want to consider is the new CarPro Denim Orange Peel Reducing Pads. It'll make a nice improvement while being a bit safer.
I know a couple of guys that have been testing them out a bit, and they say good things.
I used Meg's black wax on my old black 02 gt and it always did a great job hiding any small swirls i missed and really added to the shine and depth of the paint. Goodstuff
My point is, if that is merely the look you are going after, then you could have achieved that with any off the shelf/counter wax.
Sir, I don't mean to sound rude... But those pics don't showcase whether a "swirl remover" really did its job or not. To determine if you are swirl free, requires either sun shots or lighted shots. Meaning, swirls don't show themselves in dark lighting. They reveal themselves under reflection and when lighted up. Paint can seem glossy from afar and under dark lighting.
