Transmission
Old Apr 14, 2004 | 03:36 PM
88blueGT's Avatar
WIll a 95 GT transmission fit in a 88 GT? If it does fit will it fit without modifications? If not what will I need to make it fit? ...... ANY comments will help... thanks alot
Old Apr 14, 2004 | 03:48 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
I dont know about bellhousings, but I think it will. Dont they both use the same T5 setup. The only issue I can see is driveshaft length, but I am not 100% on that. You may want to check on some of the more technical forums regarding this.
Old Apr 22, 2004 | 02:19 PM
88blueGT's Avatar
Ok.. thanks alot.
Old Apr 23, 2004 | 08:14 AM
StangII's Avatar
Input shaft on the 94 95 t5s is a little bit longer than the earlier t5s.
Im actually looking for a 94 95 t5 because this setup will work well in my II. With earlier t5s i would have to use a pilot bushing adapter to make up the difference in the length.
Old Apr 23, 2004 | 01:53 PM
88blueGT's Avatar
Im sorry i didnt state this before i posted the chat but my car is an automatic... does that make a difference and if I would still need a pilot bushing adapter, where would I find one at?
Old Apr 26, 2004 | 09:22 AM
StangII's Avatar
Im not 100% sure on the autos but logic dictates that if the input shaft is longer on the t5 it will be on the auto as well. I would definitely check this before you do the swap. The problem for you will be the shaft is to long so a bushing adapter wont help you. I guess you could always swap out the input shaft for the shorter version. Maybe someone else here can chime in on this particular swap. I know little of automatics.
Old Apr 30, 2004 | 09:09 PM
88blueGT's Avatar
Thanks alot... I really appreciate the help.
CiniZter
25
Apr 28, 2016 05:41 PM
Rando
Sep 30, 2015 12:28 PM
Mustang65bob
Sep 21, 2015 11:30 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
