Sloshing sound
Old Oct 18, 2011 | 08:25 PM
buster58's Avatar
Sloshing sound
I have a 07 convertible and when I shift into gear and the car starts to slightly move there is a sloshing sound come from the back left side of the car. Is it because of a leak or as some have said or is it gas sloshing around in the gas tank.
Old Oct 19, 2011 | 08:01 AM
CO_VaporGT_09's Avatar
Does it happen when you're nearly on empty, the same as when the tank is full? Should answer your question. Only thing back there is the gas tank, a saddle style with compartments on each side of the transmission tube. Everything else is mechanical.
Old Oct 19, 2011 | 11:08 AM
Planeswalker's Avatar
Have to agree with what Vapor said, pretty much the only thing that could "slosh".
Old Oct 20, 2011 | 12:31 PM
Coupe Guy's Avatar
I have heard that sometimes rain water can get into the convertible area down into the quarter panels which can cause the sloshing noise. There may be a TSB about this.
Old Oct 20, 2011 | 12:47 PM
HOSS429's Avatar
legacy Tms Member
the cure i have always used for unexplained noises is to turn up the volume on the radio a bit more ...
Old Oct 20, 2011 | 08:23 PM
buster58's Avatar
I filled up the gas tank and the sloshing sound is still there. Sounds like its coming from the passenger side rear quarter panel. Anyone know where it could be leaking into and where the drain plugs might be located?
Old Oct 20, 2011 | 09:57 PM
You can strip back all the trunk lining stuff and take a look around. There are a couple of areas that aren't accessible, though.
That would really suck if it's inside one of those panels.
Old Oct 21, 2011 | 12:55 PM
FordService's Avatar
Hi buster58,
Welcome to the forum. My name is Deysha with Ford Customer Service. The members here have loads of good info. I recommend you make an appointment with your Ford dealer for diagnosis. You can also PM me your VIN, dealer, contact info, and current mileage so I can check on your warranty status and see how I can help. Have a good one!
Deysha
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
oldnjguy
Sep 10, 2015 02:39 PM
