plastidip or clear bra?
Seeing how easy it is to use, what are the pros/cons using plastidip to protect your finish on roads trips or track days vs. clear bra? Maybe the detailer savvy could weigh in on what could be damaged too.
Ahh, now the helpful weigh in, thanks guys. 2 Go, I was referring to the 3M type custom precut film commonly referred to as ClearBra, vs. the spray on coating, fyi. I wouldn't dare use the old fashioned bra!
Charlie, can anyone apply that, does it peel off easy, and how cost effective is it, if you would like to just use it for a road trip then get rid of it?
They say it peels away. Mine has been on 5 years now and zero problems. I paid a pro to install it on my Bullitt.
Yes anyone can apply it but compound curves are more difficult. I should have had help when I did my Cruiser because I couldn't quite stretch it well enough for the compound curves it has and so I have a few puckers around the headlights. The kit from Invisible Mask gives you a spray bottle for soapy water (keeps it moveable while applying) and another for alcohol (which makes it tacky and setup while applying) - you can go back and forth until you get it situated just right. They also included a dvd, and their pattern was cut perfect. I also bought extra that I cut for door jambs, edges, rear bumper cover so I don't scratch it taking stuff out, etc. Sections without compound curves are a snap - even though I was a first timer.
It is not cost effective for temporary use. But more than a few feet away you don't even notice it so why remove it?
Pain in the *** to get off, but it can be removed. Professionally installed it can cost about $500.00- $600.00 but would really protect your car and is virtually invisible on most color cars.
Wax will build up on the edges and requires a bit of extra TLC.
