Picture exchange
pulled each part off and sprayed it down with gotta have it green OEM paint. Each panel and door assembly is sprayed as well. under the hood the engine cover is sprayed with Gotta have it green and white, and the hood latch is dipped with snake print.
oh ok, I was under the impression those dash pieces didn't just pop off. Specially the air bag side. So they do?
yes, but be sure to take the fuse out for the air bag first. After you do, start the car and the air bag light should stay on-this ensures you have the right fuse. A lot of work but it gives the interior the wow factor. Hope that helps
