Opinion On The C4
I have a 88 GT Automatic 5.0 and the transmission in it is totally shot to death. I need a new transmission to fit my needs and I was looking at the AOD to C4 conversion kit fromPerformance Automatic. I was just wondering if anyone here has had any experience with the C4 and what did you thought about them if you did. It sounds great but I havent spoken to anybody whos had personal experience with them. Here is a list of what the kit comes with. If anyone would have any suggestions on something that the kit does not include that I might need, please let me know. Thank You.
-C4 Competition Transmission with Reverse Manual Valve Body
-10’’ Pro Launch Torque Converter with Stall Range from 3000 to 4000
-SFI Flywheel 0, 28, 50 oz.
-SFI Pro Fit Bellhousing
-18000 GVW Transmission Cooler that will handle summer street use
-Custom Design Dipstick and filler tube with lock top and hat seal
- ‘’How To’’ Instructions for a Complete and Easy Changeover
-Hurst Quarter Stick
-Self Locking Torque Converter nuts and bellhousing bolts
-Complete set of fittings and cooler lines- NOTHING ELSE TO BUY
-Neutral safety switch, shifter cable, brackets. Easy to adjust
-Deep Aluminum Transmission Pan with Built in Drain Plug
-Pro Shift Servo
-Nuts, Bolts, and misc. Hardware. EVERYTHING YOU NEED
-Shipping Anywhere in the Continental United States VIA U.P.S.
-Capable of handling 750 horsepower
-SBF Block plate
The ENTIRE KIT IS SELF CONTAINED- JUST BOLT IT AND ADD FLUID
$2,599.00 INCLUDES SHIPPING AND ALL CORE CHARGES
-Pro Shift Servo
-SBF Block plate
It's a good swap for a drag-only car. I can't imagine doing that on a street driven car though. It's tough as heck, but it'd just kill any highway driving. I have a C4 in my 66, and it is a good transmission. It isn't crazy built like the one you are looking at, so I'm sure it is a different animal. Us classic folks have an expression: "You know your C4 is working correctly because it is leaking". I'm sure it is possible to have a good running C4 that doesn't leak, but I haven't run into one.
Originally posted by 88blueGT@August 2, 2004, 8:37 PM
are you not recommending it as an everyday driver because it does not have an overdrive?
Sep 23, 2015 03:21 PM
