Mustang wheels on a Camaro?! Help me please! :)
1 Post
Not going to work.
If you have a wheel with 30-mm offset and an adapter with a 31.75-mm thickness, the effective offset will be -1.75 mm.
Don't believe the two posts above mine saying the effective offset would be 61.75 mm.
If your boyfriend is hell bent on using those wheels, a correct PCD can be drilled granted that the mounting pad has sufficient area. The use of steel lug seat inserts is highly recommended. The mounting pad can be shaved a few mm to increase the offset at the cost of strength, but it would not get significantly closer to 50 or 55 mm.
All these things considered, by then a set of wheels from Forgestar would be more feasible.
Hm. I may be wrong too, in thinkin' it over a tad... Perhaps I was ill.
Whatever, simply don't do it. It's easier to just give in to "it won't work" than advise bein' unsafe or such.
/meh.
//Stock works wonders.
/meh.
I never thought this could get so complicated!! I told him just to put the Ford 8.8 rear end in his car and call it good :P at least the rear end would work haha
Another hell-bent way to do this is to drill the hub flanges and the rotor hats in the correct PCD (i.e. Ford PCD of 5x114.3). Again, by then, might as well get correctly-sized wheels in the style desired.
See if ZR1-styled wheel is close enough. The C6 ZR1 wheels, not the C4 ZR-1.
1 Post
TSW Nurburgring they are very close to what you are looking for to fit a Camaro. http://www.wheelsnext.com/wheels-tir...al%20Flat.html
RedCandy5.0
10/4/15 06:51 AM
MRGTX
7/21/15 02:08 PM
7/20/15 06:26 AM
