Manual tranny tips
Manual tranny tips
So I've owned manual tranny's before but never on a sports car and thus lack the experience/strategy for proper shifting techniques. I taught myself how to drive stick and as a result had a few bad habits. For instance I didnt even know what the powerband was, I just knew all my automatics shifted around 2600rpm so I'd speed shift through all the gears no matter how hard I was accelerating trying to keep it under 3k rpm at all times I didnt even know you are supposed to downshift to lane pass. I'd just mash the pedal and wait for the car to build speed in whatever gear I was in. It wasnt until I saw youtube videos of people hitting 6k rpm's that I realized you shift depending upon the circumstances, not just the speed.
A buddy of mine was talking to me about how he loves downshifting to 2nd in his mustang around a turn, another eye opener to me when it comes to how you are *meant* to drive the car. Or canyon carving videos where people ride it out in 3rd most of the way and like 4-5k rpms the whole time.
I just read about most people with 3.73 gears start in 2nd gear when daily driving just to save some legwork from 1st since the car can take off like this without issue. I imagine you could probably skip 3rd too if you're just cruising up to normal speeds.
So all that being said, anyone have any particular tips for comfort/sport shifting patterns in a 2015 GT with performance package? I know it's mostly a "feel" sort of thing.
These new 5.0's have a lot of torque. Starting in second is very easy, and yes you can probably pass third if you have enough rpm's. To me it's more about how engine sounds than the feel when rowing through the gears. Practice, practice, practice, and you'll get there. Watch your tach, and listen to the engine. In time you will just know when to change. Staying under the tach redline is where you want to be so your engine will be happy, happy, happy.
BTW, you do not want to drop into second gear when your speed is to high. That's a good way to break something.
How do you feel about engine braking in the 5.0? Good way to save gas or just asking for trouble? Especially at the drag strip, I dont want to go flying off into the woods once I cross the line, should I just eat my brakes up and deal with it? Or can dropping to 3rd and then 2nd have a meaningful slowdown?
This is true, and brakes are cheaper than a clutch, but I hate brake dust from the Brembos, and I love hearing the exhaust burble and pop as it decelerates, so screw my stock clutch!
My mustang is automatic, but I had 2 other manual cars that I had put over 70,000 and 110,000 miles on their respective original clutches. What previous posters are saying about brakes being cheaper than clutches is absolutely right.
Sure it sounds cool downshifting into 2nd and powering through a curve, but make it only an occasional thing and use your brakes as a general rule. Smoothness is the key to any car's longevity, and the even wear of its parts.
Did I ever ignore that? Yes, absolutely - a car needs an "Italian tune-up" every now and then, as my dad would call it.
Another quote from a VW repair book I have... "Be kind to your ***, for it bares you".
I used to engine-brake with my Jeep but I won't with my Shelby as the stress on the transmission is avoidable and brakes are much less expensive to replace/repair. It's really that simple. Transmissions are built to drive, not be driven. Keep that in mind.
9/10/15 12:44 PM
