Jacking up the rear end
Old Sep 3, 2016 | 11:51 AM
garyb900's Avatar
Is there a safe way to jack up the rear end of the car all at once rather than doing one side at a time? (2005 S197)
I have read that you should NOT jack it up from the differential but I don't see any other way to raise the rear all at once.
I have also read that doing one side at a time to get the whole rear end in the air puts stress on the axle tubes since you would have one on a jack stand while the car is on an angle.
I have jack stands so I will be using those but I just want to jack it once and be done.
Thanks for any safe and sound suggestions.
Old Sep 3, 2016 | 03:10 PM
redonblackpony's Avatar
Many people including myself jack up the rear of the car by placing a jack with a block under the "pumpkin". I've been doing this for 5+ years, and I'm always wrenching on my car. Perfectly fine
Old Sep 3, 2016 | 03:45 PM
garyb900's Avatar
Thanks for the info.
Old Sep 3, 2016 | 09:58 PM
I have always jacked up my 07 this way
Dozens of times
Just make sure it's centered and balanced and go up easy.
Old Sep 4, 2016 | 03:28 PM
garyb900's Avatar
Thanks guys.
Put a block of wood on the jack pad and put it just in front of the diff. cover on the flat spot.
Worked fine.
Old Sep 4, 2016 | 08:33 PM
Cavero's Avatar
Originally Posted by garyb900
Thanks guys.
Worked fine.
Be careful. I'm one of the few where it didn't turn out so well. You know how normally as you're lifting, the jack rolls under the arm as it pivots up? Mine didn't do that. So as the arm pivoted, the jack basically pulled itself out from underneath the pumpkin and ripped open the stock diff cover. Also bent the panhard rod. Luckily I was smart enough not to be underneath the car when I was lifting it, otherwise I wouldn't be here to type this. Lots of people lift by the pumpkin without a problem, but after my experience I'll never do it again.
Old Sep 9, 2016 | 05:21 AM
Gabe's Avatar
I always lift under the pumpkin also.
Just had both cars up on 4 jack stands, lifted the front first then the rear
BlackGTCS
May 23, 2016 06:43 AM
BigChief5890
Mar 7, 2016 09:09 PM
Detroit Steel
Feb 26, 2016 06:01 PM
JeffreyDJ
1994-2004 V-6
May 1, 2004 08:47 PM
