Issue or the way the car is supposed to start?
Old Mar 28, 2013 | 10:16 AM
non compos mentis's Avatar
I just started my 2011 stang after sitting for te winter, I noticed that when I turn the key whether its starting it or turning the ignition on, I hear what sounds like the fuel pump going (seems loud) then the halo lights in the instruments dim and flicker before it starts, is this normal? When j started it for the first time last night, the needles in the gauges vibrated back and fourth making a weird noise before did their normal routine of maxing out and returning to zero. Issues?
Old Mar 28, 2013 | 11:50 AM
rriddle3's Avatar
Fuel pump - normal.
Flickering dash lights; noisy, vibrating gauges - Not in mine.
Old Mar 28, 2013 | 12:49 PM
skunk21's Avatar
Battery could be weak. 12.6V is fully charged, 12.4V is roughly 75% and 12.0V is about 25%
Old Mar 28, 2013 | 01:10 PM
That's what I figured, battery may be weak. The needles on the gauges vibrated and made a noise only on the first startup since sitting for the last 2 months
Old Mar 28, 2013 | 10:18 PM
vistabluenorange's Avatar
I had to charge the battery and let mine sit and run for awhile to let her work out the kinks by herself but she wasn't that bad because I periodically took my cover off and fired her up throughout the winter
Old Mar 29, 2013 | 06:08 AM
Stevedotmil's Avatar
Gotta get a trickle charger/battery tender for next winter. Battery is weak for sure. Should be fine after you spend some quality time driving your car around.
Old Apr 5, 2013 | 07:49 AM
FordService's Avatar
Hello non compos mentis,
I recommend you bring your vehicle in to your Ford dealer for diagnosis. Then, PM me with your VIN, dealer, mileage, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
chadh92
Jul 29, 2015 06:56 AM
Kev006
Jul 8, 2015 05:29 AM
