I had my tail lights sprayed to darken them.
Old Sep 24, 2011 | 04:57 PM
bud4au01's Avatar
they are to dark...during the day , you can barely see them...can't at all in the sun. HOW , without replacing them...do i fix this problem? Thanks
Old Sep 24, 2011 | 05:35 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Think your sol...
Old Sep 24, 2011 | 05:45 PM
start sanding.
Old Sep 24, 2011 | 06:56 PM
bud4au01's Avatar
Paint thinner?
i wonder if this would work?
Old Sep 24, 2011 | 10:20 PM
HRSPWR's Avatar
Try some brake fluid on them. It will soften the paint, and shouldn't bother the plastic.
Old Sep 25, 2011 | 10:11 PM
Kona Blur's Avatar
Either way, fix it fast! My buddy's were dark and he got rear ended HARD! Insurance wouldn't cover it bc how dark his tails where, so he had to pay to fix his own car after getting nailed at a stop light ... Weak
Old Sep 25, 2011 | 10:13 PM
Bear Eats King...
Bear ****s Bone
Ouch... I've never tinted mine, after reading this I don't think I ever will
Old Sep 25, 2011 | 11:50 PM
Kinyodas's Avatar
Get a plastic polish kit - usually at a hobby shop - start with the heavy grade and work your way down until it is acceptable and smooth with the lightest grit.
Old Sep 26, 2011 | 12:19 AM
chutoyy's Avatar
Take sand paper and start sanding until you see red again, then use a polisher and compound to buff it clear again.
Old Sep 27, 2011 | 04:56 PM
JetWolf's Avatar
Depending on what you used, you can rub acetone and it will slip right off. Then you can redo it and wet sand it for that glossy look
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
seaclam
Sep 25, 2015 01:29 PM
TMDM
Sep 24, 2015 07:00 PM
14Glassback
Sep 11, 2015 04:50 PM
