How to determine if I have a 64.5 vs . 65., Mustang Coupe
Old Jul 22, 2012 | 05:10 AM
B.R.'s Avatar
I own a Mustang., I thought to be a 1964.5., but could be 65., it has a 3 speed on floor., 6 cyl.., (not for sale either)..does anyone know how to tell the difference it is my first old car I have ever owned too. I am not a car buff so that is why I have this question-- the internet does not clearly have this answer.
Old Jul 22, 2012 | 05:14 AM
AlsCobra's Avatar
A Man Just Needs Some....
64 1/2 didn't come with chrome inserts in the side panel trim. 65 did and 66 had the fancier ones.
Old Jul 22, 2012 | 05:18 AM
AlsCobra's Avatar
Also found this.
Note: many changes came before the cut off date for 64.5 production (Sometime in early August, 1964.) and many came well into the regular 65 production.
Ford did have a shutdown period for retooling of the Mustang lines in early August, 1964. This is when the switch from generators to alternators was made. When they started back up, the VIN numbers were rounded up to 5FXXX250001 at Dearborn, and 5RXXX125001 at San Jose. To those of us in the hobby, this is the point when the 64.5's ended and the 65's started.
For the purposes of this list, the early version of a difference will be called "64.5" and the later version will be called "65". This does not mean the the items were only found on pre-shutdown or post-shutdown cars. There was a lot of overlap before and after the shutdown.
We will try to note when the change occurred if it is known...
Old Jul 22, 2012 | 05:21 AM
AlsCobra's Avatar
http://www.mustangmonthly.com/thehis...964/index.html
Old Jul 22, 2012 | 07:32 AM
welcome BR hope ya stick around after you get the info your looking for. Post a pic or two of your ride
Old Jul 23, 2012 | 01:56 PM
mannyfreshS197's Avatar
You can do a search on google for the mustang vin decoder..vin number is stamped on left fender inside the hood and also on the driver door..you input the vin and the decoder breaks it down to the options the car came with like color, interior color, motor,tranny, etc..and it tells you the actual build date..that's how I found out my 65 was built September 8 1964.
Old Jul 23, 2012 | 03:41 PM
11SHELBYGT500's Avatar
It's a 1965, no such thing as a 64 1/2
PonyShow
V6
Nov 17, 2017 02:00 PM
ustabawannab
Aug 5, 2015 08:32 PM
killaz05
Jul 24, 2015 08:49 AM
