Help!! Have a spraying hose and need help please!
Link to image - http://customerpics.americanmuscle.c....php?img=25391
I need help! I have a 98 Mustang that I recetnly got from family. I need to know what is the hose under the upper radiator hose, also under the small red hoses - it seems to be spraying a substance that seems to be antifreeze. It is spraying antifreeze all over the engine/ battery/ everything. It seems that this is spraying from where the hose meets the engine. I do not believe the hose broke or something, its possible the clamp that holds it in place got loose or something.
Please bear with me, I know NOTHING about cars and cannot afford to do all kinds of work now. Can any1 help me??? I need to know what hose it is and if the fix can just be to replace the hose, or could it be worse.
Allan
Go to your local parts store and tell them. Its just a busted hose and are very easy to replace yourself.
I'm guessing because i can't see your pictures.........
