Help
Help
Can someone please give me some much needed advice on how to connect a subwoofer to the factory amps in my 99 mustang convertible... and the pros & cons ...
YouTube videos are a very good source that provide step by step instructions.. In my honest opinion, YouTube would be your best option and I'd start there.
Neen (4/26/22)
Anytime
I will buy Jack Stands!!!
If you want to add a subwoofer and a dedicated amp (would most likely sounds best), that can most likely be achieved by a Line Out Converter (if you want to keep the factory stereo head unit), or by swapping to an aftermarket head unit and adapter harness.
m05fastbackGT (4/28/22)
I'm not sure an SN95 ever came with a factory subwoofer, though I could be wrong. I know the Mach 460 system didn't have a dedicated subwoofer to speak of. I think they were like the Shaker systems, and used the larger, lower door speakers as "subs." IF that's the case, then you could re-route the speaker wires going to the lower door speakers, or even T them off, to feed power/signal to a standalone subwoofer.
I'm also not really certain if the Mach 460 systems had a dedicated subwoofer either.. I don't ever recall seeing a 99-04 SN-95 new edge that had one.. Perhaps there might be a subwoofer line-out behind the Mach 460 head unit, but I wouldn't count on it. Therefore, I fully agree if the OP wants to add a subwoofer to his factory head unit, his best option would be connecting a line-out converter from the head unit to a dedicated amp.. I'm not even certain if the Shaker 500 head units have a dedicated line-out, whereas the Shaker 1000 systems do have a factory 10" subwoofer located in the trunk compartment.
Just another fine example of Ford's marketing strategy at work
