Gear changing issue.
Old 11/26/12, 10:12 PM
Mickstang's Avatar
Originally Posted by AnnieSialo
Hi,
I used to think that pressing the clutch was essential to be able to change gears, since that was the only way of disengaging the engine from the driveshaft, and then you could change the gear. I guess I was wrong.
Anyways, am curious to know how does one change gears without using the clutch? How does it work and are there any issues that might arise as a result of this?
A damaged transmission is the first issue that comes to my mind. If normal shifting procedure is problematic for you, you might have been better served with an automatic transmission... just sayin'.
kponypower
6/17/20 07:17 AM
Autotooner
11/24/17 12:42 PM
ricky1728
2/11/16 07:25 PM
DerekShiekhi
9/30/15 06:59 AM
Quick Reply: Gear changing issue.
