Gear changing issue.
I was taught driving manual by my father, and far I as know, I have to step down the clutch when changing gears.
However, do I have to step down the clutch when shifting into neutral? I feel like its impossible to shift into neutral from 1st and 2nd gear without clutch, but 3rd and 4th gears are fine without clutch.
Any thoughts?
Thanks a lot.
Any thoughts?
Thanks a lot.
Clutch for everything. And if youre going too slow then brake wth the clutch so you dont stall.
If youre in 3rd or any gear you push down and put it in neutral. You need to use the clutch when you shift all the time too
And when youre backing up
However, when shifting into neutral from 3rd and 4th, it worked even without stepping down the clutch.
Originally Posted by pcpctc520
Far as I thought, clutch is like a lock, it is required when shifting into any gear. Without clutch, u shouldn't be able to shift at all.
Thats not normal though. Take it to the dealer!
Youre right
Well, I just googled it. And looks like lots of ppl are having the same issue. Or it's not even an issue since every manual car has it.
Are you saying the tires and wheels you have are stock size? You need to make sure you're running the same diameter as stock if they're not.
Yup, they are stock. Didn't even change a bit.
I think I mixed up your two threads. I didn't realize this was about 3rd and 4th gear. I'll say this about that, it's perfectly normal and easy to be able to pull out of 3rd and 4th without engaging the clutch
You are correct! It is recommended that you engage the clutch while shifting. That includes shifting into gears and shifting out of gears.
Although it is possible to go from 3rd and 4th gear into neutral without using the clutch, it is always recommended. It may seem easier because there is less tension, but not using the clutch may eventually do harm to your transmission.
I hope that helps. Have a wonderful evening!
Andrea
Any thoughts?
Thanks a lot.
Any thoughts?
Thanks a lot.
Originally Posted by FordCustomerService
Good question! ...and here are some good answers...
'Stang fans,
pcpctc520 and 11SHELBYGT500,
Andrea
This is really helpful. Thanks a lot.
You're very welcome, pcpctc520; anything to help my loyal Mustang fans. Please feel free to reach out to me with any questions or concerns you have in the future.
Andrea
Andrea
Andrea
Andrea
They look really nice, but the front wheels rub when making a full lock turn (either left or right).
So, I searched online and looks like steering stop help. My question is, will the wheel spacers help as well.
Mike
I'm not buying the "steering stop" alibi. Lol
I'm running 255/40/18s in front and have made some crazy hard turns with no rubbing.
