Gear changing issue.
Old Nov 10, 2012 | 12:19 PM
pcpctc520's Avatar
I was taught driving manual by my father, and far I as know, I have to step down the clutch when changing gears.
However, do I have to step down the clutch when shifting into neutral? I feel like its impossible to shift into neutral from 1st and 2nd gear without clutch, but 3rd and 4th gears are fine without clutch.
Any thoughts?
Thanks a lot.
Old Nov 11, 2012 | 05:02 PM
marjamr's Avatar
By nitro I assume you mean neutral. My practice has been to always engage the clutch when shifting into any position including neutral. What do others think.
Old Nov 11, 2012 | 05:14 PM
mopar?'s Avatar
Clutch for everything. And if youre going too slow then brake wth the clutch so you dont stall.
If youre in 3rd or any gear you push down and put it in neutral. You need to use the clutch when you shift all the time too
And when youre backing up
Old Nov 11, 2012 | 05:22 PM
pcpctc520's Avatar
Far as I thought, clutch is like a lock, it is required when shifting into any gear. Without clutch, u shouldn't be able to shift at all.
However, when shifting into neutral from 3rd and 4th, it worked even without stepping down the clutch.
Old Nov 11, 2012 | 05:49 PM
mopar?'s Avatar
Youre right
Thats not normal though. Take it to the dealer!
Old Nov 11, 2012 | 06:24 PM
pcpctc520's Avatar
Youre right
Well, I just googled it. And looks like lots of ppl are having the same issue. Or it's not even an issue since every manual car has it.
Old Nov 11, 2012 | 06:26 PM
11SHELBYGT500's Avatar
What size and brand tires are you running in the rear?
Old Nov 11, 2012 | 07:20 PM
pcpctc520's Avatar
stock and 225/17
Old Nov 11, 2012 | 07:36 PM
stock and 225/17
Are you saying the tires and wheels you have are stock size? You need to make sure you're running the same diameter as stock if they're not.
Old Nov 11, 2012 | 08:30 PM
pcpctc520's Avatar
Yup, they are stock. Didn't even change a bit.
Old Nov 11, 2012 | 08:37 PM
I think I mixed up your two threads. I didn't realize this was about 3rd and 4th gear. I'll say this about that, it's perfectly normal and easy to be able to pull out of 3rd and 4th without engaging the clutch
Old Nov 11, 2012 | 08:47 PM
pcpctc520's Avatar
Lol. That's what I thought. Btw, the new tires and wheels ill put on my v6 are also stock wheels. Just bigger and wider.
Old Nov 12, 2012 | 07:13 PM
hu171's Avatar
Clutch is everything.
Old Nov 13, 2012 | 04:23 PM
FordService's Avatar
...do I have to step down the clutch when shifting into neutral? I feel like its impossible to shift into neutral from 1st and 2nd gear without clutch, but 3rd and 4th gears are fine without clutch. Any thoughts?...
Good question! ...and here are some good answers...
Originally Posted by marjamr
...My practice has been to always engage the clutch when shifting into any position including neutral. What do others think.
Clutch for everything...You need to use the clutch when you shift all the time...
'Stang fans,
You are correct! It is recommended that you engage the clutch while shifting. That includes shifting into gears and shifting out of gears.
Far as I thought, clutch is like a lock, it is required when shifting into any gear. Without clutch, u shouldn't be able to shift at all. However, when shifting into neutral from 3rd and 4th, it worked even without stepping down the clutch.
...it's perfectly normal and easy to be able to pull out of 3rd and 4th without engaging the clutch
pcpctc520 and 11SHELBYGT500,
Although it is possible to go from 3rd and 4th gear into neutral without using the clutch, it is always recommended. It may seem easier because there is less tension, but not using the clutch may eventually do harm to your transmission.
I hope that helps. Have a wonderful evening!
Andrea
Old Nov 13, 2012 | 04:41 PM
Shelby08's Avatar
Any thoughts?
Thanks a lot.
While technically you can shift without the clutch through all gears...I don't do it in my mustang much BUT I used to do it in my truck all the time mostly because it was a POS...but I would go with what everybody else says use your clutch...your car is a bit nicer than the truck was...
Old Nov 13, 2012 | 06:38 PM
pcpctc520's Avatar
'Stang fans,
Andrea
Finally some answer from official.
This is really helpful. Thanks a lot.
Old Nov 19, 2012 | 03:21 PM
You're very welcome, pcpctc520; anything to help my loyal Mustang fans. Please feel free to reach out to me with any questions or concerns you have in the future.
Andrea
Old Nov 19, 2012 | 04:42 PM
pcpctc520's Avatar
Andrea
One issue I have right now. I just recently purchased a set of 10 GT wheel to switch my V6 stock wheels.
They look really nice, but the front wheels rub when making a full lock turn (either left or right).
So, I searched online and looks like steering stop help. My question is, will the wheel spacers help as well.
Mike
Old Nov 19, 2012 | 04:54 PM
Getportfolio's Avatar
I'm not buying the "steering stop" alibi. Lol
I'm running 255/40/18s in front and have made some crazy hard turns with no rubbing.
Old Nov 19, 2012 | 05:01 PM
pcpctc520's Avatar
Mine are only 245. Not sure why they rub.
