dumb question probably
Old Jan 2, 2013 | 10:30 AM
firstcarstang's Avatar
Do they make a curved exhaust tip? I am trying to avoid having the little amount of the bumper cut so one will fit on
Old Jan 2, 2013 | 11:34 AM
Getportfolio's Avatar
Exhaust tips have hangars and are adjusted in the cutout of the bumper accordingly.. There's no curved exhaust tips. everything is fitted at the pipes before you even get to them.
If you mean to say that you don't have cut outs for the tips to exit your rear bumper, then you can bend the pipes down a bit using the hangars. However, They will still be straight. (Just pushed down at an angle)
It looks better with a bumper with exhaust cutouts though.
Old Jan 2, 2013 | 12:29 PM
I have a v6, non dual exhaust, so no cutouts. Thanks for the help!
Old Jan 2, 2013 | 12:43 PM
Go side exhaust. Looks best if you're not going to get a GT bumper. Or check eBay/mpsautosalvage.com for a takeoff GT bumper. There's hundreds of thousands of 99-04 SN95s out there - I'm sure you can find a decent bumper already painted your color, for cheap.
Old Jan 2, 2013 | 12:57 PM
Kevin509's Avatar
If you don't want side exhaust you can get what are called turn down tips. That's what you mean when you say curved tips I believe.
Old Jan 2, 2013 | 01:11 PM
AlsCobra's Avatar
A Man Just Needs Some....
An exhaust shop can do any curved tips you want. It won't cost you much.
Old Jan 2, 2013 | 01:37 PM
Forgot about those... Noooooooooo!!
Old Jan 2, 2013 | 01:58 PM
What's wrong with those?
Old Jan 2, 2013 | 02:00 PM
I just dont want to make cutouts in my bumper, if that's avoidable.
Old Jan 2, 2013 | 02:01 PM
The turn down tips are not very pretty.
Old Jan 2, 2013 | 02:10 PM
Will that keep me from making cutouts though?
Old Jan 2, 2013 | 02:14 PM
You can do all kinds of things. You don't have to use cutouts. I've seen sixers run straight tips with no cutouts.
Old Jan 2, 2013 | 02:34 PM
Kevin509's Avatar
The turndowns will prevent you from making cutouts yes. And it doesn't matter if they're ugly because nobody will see them if they're behind the bumper haha.
I have heard that they increase interior drone though because the sound is bouncing against the ground and back up into the car rather than exiting out the back.
Old Jan 2, 2013 | 02:35 PM
I thought you had to to use straight tips, at least that's what I heard
Old Jan 2, 2013 | 02:36 PM
Correction to my statement: iI thought you had to make cutouts for straight tips
Old Jan 2, 2013 | 02:37 PM
I would like to hear it more inside, cause its barely audible from inside, and it sounds pretty good outside
Old Jan 2, 2013 | 02:57 PM
Kevin509's Avatar
Well they're super cheap on eBay, or any local muffler shop can put them on for not much more. Might as well do it and see what you think.
Old Jan 2, 2013 | 04:04 PM
I ran turndowns on my V6 for a long time, until I got a GT bumper for free. I liked it. Made the exhaust deeper and I had then tucked up into the bumper like the Fox GT cars. Just looked like the exhaust was dumped. I had a custom set up made by a shop. Btw, for the best sound on these cars, don't do an H or X-pipe. Leave the two pipes separated, so each pipe starts from the cat back and goes all the way back. No crossover pipe. It sounds the deepest, and for smog, it will pretty much make your car pass with flying colors because the sniffer is only reading 3 cylinders
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
