Cant get into car
Old Jul 8, 2019 | 10:22 AM
Gabriel Pineda's Avatar
Cant get into car
I have a keyless ford mustang but theres no way to insert the key to unlock the door and the battery is dead in the car so the key fob wont work.
Old Jul 8, 2019 | 02:42 PM
call a local lock smith. Get a second key fob first if you can. that way he can program your new fob as well as get your car open. If not DRINK
Old Jul 8, 2019 | 06:25 PM
houtex's Avatar
What year car.
Old Jul 8, 2019 | 07:49 PM
The car is 2004 and theres no keyhole
Old Jul 10, 2019 | 05:12 PM
houtex's Avatar
All 2004 Mustangs have a key cylinder in the doors. Both sides. Unless I'm mistaken and that car is *really* special...
So, with that, if yours has no keyhole on either side, then it's been removed/vandalized, and you should get a new set complete with ignition cylinder so the three will match like they should. Or if the key you have doesn't work in the doors, then the ignition cylinder is likely mismatched, probably due to it being replaced, and the door key is missing, hence the issue maybe?
In any event, the call to a locksmith to get in the car is a good call,
or get one of these things and unlock it yourself. or get one of these things and unlock it yourself.
And the new set of keys/ignition/door cylinders, an example, notasponsor.
One more thing: You can open the hood of that Mustang, as the latch is exposed there, so you should be able to figure out how to unlock it from the grille/under the bumper. Think you can just pull on the cable firmly, but not yanking, and it should maybe get to where you can trip it open. Plug in a charger, voila, fob is working... maybe.
Hope that helps, good luck, and I don't think anyone said this... Welcome to the forums!
Old Jul 11, 2019 | 07:31 AM
My 04 had only had a key hole on the drivers side. I say bust out the windshield... its the easiest way to get in there
Old Jul 11, 2019 | 02:06 PM
David Young's Avatar
I have to agree with Glenn. Bust out the windshield and you'll have access to everything you need
Old Jul 12, 2019 | 07:39 AM
well I was thinking cut a hole in there using a diamond cutter but cut the hole at an angle like you would a pumpkin. That way you can just glue it back in after you get in the car.
Tom Davis
1994-2004 V-6
Apr 28, 2016 07:29 PM
scotts05custom
May 30, 2006 10:53 AM
JHL981
05-09 Interior and Audio Mods
Apr 7, 2005 09:05 PM
JHL981
Mar 27, 2005 12:03 PM
