Cant get the rear speaker grille off
Old Mar 30, 2005 | 03:59 AM
JHL981's Avatar
Is it glued on? I wanted to isntall my aftermarket speakers but it wouldnt lift up or anything. So I ended up putting them in the doors since I figured it out! Whats the deal?
Old Mar 30, 2005 | 05:13 AM
Sonic Thunder's Avatar
you have to take out the seats and loosen parts of the side panels in the rear, then lift up the entire area where the speaker is. Sounds like alot...not bad as it sounds though, about a 15 minute job.
Old Mar 30, 2005 | 06:32 AM
Tiberius1701's Avatar
Nope,
Just take a small flat bladed screwdriver and gently pry up on the grille at the inner front corner and remove it-it just snaps in place, four screws hold speaker in place, use caution not to damage defrost grid when removing screws and speaker.
Old Mar 30, 2005 | 08:08 AM
oatmeal's Avatar
Hehe this thread is gold.
"Remove seats, do some wierd disassembly trickery"
"nah just use a screwdriver and pry the mother!"
Old Mar 30, 2005 | 09:11 AM
Here is the manual procedure pdf.
Old Mar 30, 2005 | 12:16 PM
JHL981's Avatar
So when you mean inner front corner, are you reffering to the corner thats closest to the window?
Old Mar 30, 2005 | 11:23 PM
kevinv-6's Avatar
mine just popped out with a flat head screwdriver. now getting the screws off, thats a pain
Old Apr 3, 2005 | 02:51 PM
Inboard front corner of grille. Toward center of car.
Old Apr 3, 2005 | 08:20 PM
Eric's Avatar
Getting the screws out IS a pain; first of all, they're hex or torque screws. I had success, tho, with a hex wrench set that has varying sizes and folds up like a jacknife... cost me probably 7 bucks ten years ago, but folds up enough to fit the back screws. Good luck.
Old Apr 7, 2005 | 09:05 PM
dave_bought_another_black_stang's Avatar
Tiberious, where did you get that PDF? I needed to replace the inner rubber gasket on my windows because the factory gasket/regulator scratched my windows, and it would have been nice to have a drawing like that.
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
