2009 Ford Mustang 45th Anniversary Air Conditioned problems
Old Apr 29, 2014 | 06:43 PM
bebo33's Avatar
I've had this car for 4 years and bought it with less than 10k miles on it. It has 46K. Car runs and drives great, but started blowing warm air last week. I decided to put some freon in it and after getting the can hooked up, finding the low side of the unit and putting on the adapter it wouldn't take the freon. I cranked the car put the ac on high recirculating the air hoping it would aid in removing the freon from the can. No luck. I've never had an issue putting freon in any of my other cars in the past or my truck that I drive daily commuting back and forth to work. Scratching my head! This is my first Ford that I've had except for a Ranger I had back in High School many moons ago. Any ideas of suggestions to help me figure out this problem would be greatly appreciated.
Old Apr 29, 2014 | 08:28 PM
houtex's Avatar
Your blend door actuator is likely not working, and the fail mode for that is 'hot'. Which is nice in the winter, I suppose, but sucks for summer.
It's located on the right side of the plenum assembly, and you can look at it by taking the glove box out of the way, as specified here:
http://iihs.net/fsm/?dir=336&viewfil...r Actuator.pdf
Here's a pic of it, among others, of the part in it's natural habitat:
https://www.google.com/search?q=19E6...ml%3B640%3B480
And here is but one example of a price and a pic of the item in question.
http://www.group1autoparts.com/ford/...-control-motor
Hope that helps!
Old Apr 30, 2014 | 06:06 AM
AzPete's Avatar
If it is not a blend door issue, then you may have been so low on freon that the low pressure switch needs to be jumped to open the system.
Old Apr 30, 2014 | 06:37 AM
did the gauge on the freon read that your system had enough pressure? You did have a gauge on the freon...yes?
mark0006
Sep 8, 2023 09:46 AM
MELLOWYELLOW06
Jul 21, 2015 11:59 AM
Jul 20, 2015 06:26 AM
Jul 17, 2015 05:40 PM
Detroit Steel
'10-14 Roush Mustangs
Jul 13, 2015 01:04 PM
