Not Seeing All Threads
Happened in another forum, but even see it in this help forum. Go to the forum home page, look at this help forum. Says the last post is July 21. Click on the link to go here (URL is http://forums.bradbarnett.net/forumdisplay.php?f=27 ).
It shows the sticky threads and that's it.
Where's the rest of the threads?
Look all the way at the bottom. You'll see drop down menus. Click the one that I have expanded in the screen shot and select beginning. Works this way in all the sections here (and most sites)
That's really not the best solution as I'd have to do that for every section. I look in my options and note I have my thread display settings set to "Use forum default". Set it to "all" and I see everything in all forums.
I cleared all cookies and looked around as a guest. This forum defaults to "today", while the SN95 forum defaults to "the last month". True of other forums as well, the display range varies per forum.
The default should be consistent across all forums and probably should be a bit longer than one day.
I thought I had moved everything to the last month. I'll have to go back through and check.
Rando
Aug 25, 2021 11:12 AM
