Fox driver from Florida
Hello my name is Parker, I live in Fort Myers Florida and I drive a 1986 Gt.
Mod list:
Cold air intake
Underdrive pulleys
3 row Aluminum radiator
Hi flow aluminum fan
Distributor
9mm plug wires.
Msd coil.
Timing advance 15*.
Long tube headers.
Catless mid pipe
Flowmaster dumps
Firewall clutch adjuster
Lowering springs
Built rear end drake musclecars
3:73 gears
Posi rear
Lift off fiberglass cowl hood
Hood pins
Weld five star wheels
Nitto 555r drag radials
Steeda tri ax shifter
Grant gt wheel
Dual gauge pod
Cobalt a/f gauge
Volt gauge
Vac gauge
195 fuel pump
Heavy duty u joints
Weight reduction
Sway bars
![Fox driver from Florida-image-2886406753.jpg](https://themustangsource.com/forums/attachments/f650/116479d1458687221t-fox-driver-florida-image-2886406753.jpg)
Mod list:
Cold air intake
Underdrive pulleys
Distributor
9mm plug wires.
Msd coil.
Timing advance 15*.
Long tube headers.
Catless mid pipe
Flowmaster dumps
Lowering springs
3:73 gears
Posi rear
Hood pins
Grant gt wheel
Dual gauge pod
Cobalt a/f gauge
Volt gauge
Vac gauge
195 fuel pump
Heavy duty u joints
Weight reduction
Sway bars
![Fox driver from Florida-image-1846713181.jpg](https://themustangsource.com/forums/attachments/f650/116480d1458687221t-fox-driver-florida-image-1846713181.jpg)
Thanks for all the welcomes! And it's quick, but not quick enough, I'm gathering parts for a mas air conversion and h/c/i swap. Either that or nitrous
