Xbox 360 Gets the 3 Red Lights of Death
http://www.anandtech.com/gadgets/sho...spx?i=3152&p=6
Idle:
90nm -> 149 Watts
65nm -> 100 Watts
Gameplay:
90nm -> 173 Watts
65mn -> 120 Watts
Zombie/Phantom Charge:
90nm -> 2.3 Watts
65nm -> 2.8 Watts
Idle:
90nm -> 149 Watts
65nm -> 100 Watts
Gameplay:
90nm -> 173 Watts
65mn -> 120 Watts
90nm -> 2.3 Watts
65nm -> 2.8 Watts
Ok..i'm bitter now...
http://forums.xbox.com/1/15804553/Sh....aspx#15804553
Apparently I have a Zephyr board not the Falcon.
(Even though my Lot # is 735....)
It has 3 flat inductor rings (Zephyr)
3 upright = launch
2 flat = Zephyr
Power Supply is 203W which is Zephyr
175W = Falcon
Even WITH my manufacture date of Sep-17-07
However... ALL is not lost.
It seems to have the new heatsink on the GPU which causes all the problems...so I'm hoping this one will be ok...
3 upright = launch
2 flat = Zephyr
175W = Falcon
As for recommending the Intercooler, no please don't buy that. The Nyko Intercooler draws power directly from the 360s power supply, and it appears not to be very good at it. It doesn't draw very 'clean' power, and several people have gotten scorch marks around the power plug on the back of their 360 while using the Intercooler. The 'good' news? Voided warranties over the use of that device. Avoid at all cost.
Oh look something is wrong with the unit i have (wink)(wink)
I may have to return it to the store and exchange it for a new one
(its within my 60 day exchange)
We'll see how this goes
Whether or not the new heatsink helps... its way better than the launch board, but the Zephyrs without the new heatsink still have the problem.
No word yet if it'll fix it. Although I'm guessing it more than likely will.
Its got a new heatsink with heatpipe that the old units don't have.
Its not so much the CPU overheating, its the GPU which is still 80-90nm anyway (even on the Falcon board).
This is precisely why I maintain that it will not fix it, not entirely. It will undoubtedly lower the failure rate, but they still haven't addressed the two main causes of the RROD. The GPU and the X-clamps (heatsink retention mechanism).
It'll fix it if its able to cool the GPU better.
Which it looks like it should/could (can't say for sure)
Its actually got a heat pipe out to another set of fins to move the heat away from the main heat exchanger.
Yes, the newer 65nm die next year will run cooler etc,
but if the new setup is adequate, it'll 'fix' the problems...
but like you said, we won't know for a while.
