Locked Out of my PC
Well no luck with them so I stuck my head under the cold water tap for a while to cool off, I found one restore point that it did not delete, so I hit that eraser my own user as it was corrupted or what ever the live Onecare tune up deleted. & I finallyle to set up a new Admin account, I'm just trying it now to see if my goodies can be accessed. I got admin mut a lot of pics and stuff is gone my book marked pages but I have regained control I think ? I need a cold glass of milk
Nathan I'll be in touch kk
Aw man. If it deleted the account and files then you may be out of luck. Hopefully the user folder is still intact.
Try this.
Go to C:\Users\
Look for a folder with the name of your old user that you removed. If it is there you should have your pictures, documents, and all your files in there. You can simply drag them from the old location to the same location on the new user.
If this doesn't work and you are desperate to get files you could try this. It is best to download it to a USB drive and try recovering files from the hard drive and copy to the USB drive. (Your external drive)
http://www.snapfiles.com/get/restoration.html
Try this.
Go to C:\Users\
dates are there but no files oh well at least I have control again and best part I'm six feet above ground !
I appreciate all the helpful tips hints and idea's and I possed an idea that if approved by the powers that be here, a little something just because it's worth more than $50.00 bucks
Did you check under the C:\Users\username folder or just try the restoration program?
Antigini-GT/CS
10/5/15 09:43 AM
