How to secure your garage door
Old Apr 16, 2015 | 07:43 PM
tukatz's Avatar
I recently saw a video that showed how thieves are slipping the hanging hook end of a wire clothes hanger over the top of a garage door and snagging the lever that releases the trolley from the transport mechanism. They then pull the lever down with the hanger and in SIX seconds they are opening your garage door. I devised a way to prevent this and wanted to share it with you all.
Old Apr 16, 2015 | 07:47 PM
GrnT's Avatar
Ignore the pic on my post. It's the only way I could view yours. That's messed up though.
Old Apr 17, 2015 | 07:01 PM
Rog13GTCS's Avatar
Thanks for sharing. I saw that video a while back too. My release lever is designed different than yours, so I was able to run a zip tie through it to secure.
I was very close to buying one of those $30 boxes to protect it. With the box the release would still work. My method it is not functional.
What amazes me are the thieves that come up with this. Of course I'm not thinking about how I can break into someones home either.
Old Apr 17, 2015 | 08:05 PM
tukatz's Avatar
A friend in the Honda S2000 club pointed out the flaw in my earlier solution - in the event of a fire in the garage you don't want the release lever impeded. So based on an idea he had I devised a new solution.
Here is the new solution with many thanks to Dave for pointing out the flaw in the first solution. I picked up a sheet of aluminum and longer clevis pins from Home Depot. I cut two pieces of aluminum 6 inches square and drilled holes in them. They mount on the longer clevis pin and on a machine screw that goes through the hole in the arm. There are extra nuts as spacers to get the two sheets of aluminum to mount properly. The release lever is now unimpeded but the aluminum sheets extend far enough past it that a burglar can't snag it. Here are the links to photos.
http://i1115.photobucket.com/albums/...psakgbz76z.jpg
http://i1115.photobucket.com/albums/...ps8rkvsmr2.jpg
Old Apr 17, 2015 | 09:03 PM
kcoTiger's Avatar
I use a padlock.
Old Apr 19, 2015 | 11:22 AM
Rog13GTCS's Avatar
Thanks. I had not thought about a fire, or other emergency situations. Did you remove your handle from the end of your tether? They would still be able to grab it and pull down to release.
Old Apr 19, 2015 | 02:52 PM
tukatz's Avatar
Yes, the handle is off the cord. I did the one door in the photos and still have to do the other one. I just don't want to park my Stang out in the pollen while I work on the door.
Old Apr 19, 2015 | 03:01 PM
MadGT's Avatar
Legacy Tms Member
Hmmm...never thought of that one.
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
