I picked up a 2k Grand Cherokee limited
Old Mar 12, 2014 | 06:42 PM
Picked it up this past Sunday. Father son project it needs an engine rebuild 4.7 with 130k on it. We paid 750 bucks for it, hopefully the rebuild won't cost to much. We have a few bolts left to remove before we jerk it out of there.
Old Mar 12, 2014 | 07:31 PM
EastTNMustang's Avatar
Great price...good luck on the rebuild.
Old Mar 13, 2014 | 08:02 AM
Nice! I had a 99 GC with the 4.0 straight six. That engine was bullet proof!
You'll love it, no fuel mileage, but very comfortable, drives very well for an early SUV.
Do keep an eye on your taillights however, they have a problem with not working. If the contacts stop working on the bulb holder, it'll cause the lights to go out when you push the brakes. You'll either have to bend back the contact points or buy a new bulb holder, or whatever they call it. Not very well designed. I used to carry around 2 extras just because.
Old Mar 13, 2014 | 10:09 AM
Nice! I had a 99 GC with the 4.0 straight six. That engine was bullet proof! You'll love it, no fuel mileage, but very comfortable, drives very well for an early SUV. Do keep an eye on your taillights however, they have a problem with not working. If the contacts stop working on the bulb holder, it'll cause the lights to go out when you push the brakes. You'll either have to bend back the contact points or buy a new bulb holder, or whatever they call it. Not very well designed. I used to carry around 2 extras just because.
No wonder I always see GCs of this era with brake lights out, but third brake lights working!
Old Mar 13, 2014 | 01:06 PM
Old Mar 13, 2014 | 05:06 PM
David Young's Avatar
Me 3. Have fun on the rebuild
Old Mar 14, 2014 | 07:51 AM
Yea the drivers side window buttons don't work when the door is open but do work when the door is closed. The thing really is pretty clean aside from needing a cleaning. ha. The paint is taking some elbow grease but is coming out nice, shinny and smooth. Washed it with dawn clay barred it washed with dawn again hit it with some swirl remover a time or two.
The engine is almost out, then we shall see what it needs.
Old Mar 14, 2014 | 08:19 AM
yup. I tell people in GC's all the time.
They dang sure clean up well! Mine had the plastic molding on the bottom, so I really only had half a car to wax.
Old Mar 17, 2014 | 06:30 AM
this is what was left of the bearing back cylinder passengers side
Attached Thumbnails I picked up a 2k Grand Cherokee limited-bearing.jpg   I picked up a 2k Grand Cherokee limited-bearing2.jpg
Old Mar 17, 2014 | 11:05 AM
spun... I had to fix one of those on my Olds 442.
Old Mar 17, 2014 | 12:53 PM
yep my 2k was in about the same shape. Have the crank turned, replace the connecting rod and and all bearings. Check the specs on the cams, lap the valves and replace the seals. Bingo bango git er dun
Old Mar 23, 2014 | 08:49 AM
trying to figure out what I should ask for it when I'm done fixing it up. This one just sold but is in better shape with fewer miles. 6500 bucks nice http://www.ebay.com/itm/191102728959?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and here's another one, mine is in better shape than this one and of course mine will have a refreshed engine.
http://www.ebay.com/itm/291104063688?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITwe shall see what that one sells for.
I was hoping for something between 4 and 5k we shall see.
Old Mar 31, 2014 | 06:23 AM
Spun a bearing
had the crank turned
ordered all gaskets, seals and bearings
ordered a piston, rings, connecting rod and all rod bolts.
honed the cylinders and cleaned the block up this weekend.
Still need to order an oil pump and timing gear and chain set.
I going to lap the valves myself and replace the guide seals.
I still need to fix the camber, just looking at it I know its to far off.
Replaced one headlight to match the other new one the previous people installed.
Dan is in the process of painting the wheels. The clear coat is flaking off.
Clay bared followed that up with some swirl remover and then threw a coat of wax on it. Looks purdy good.
Interior is all detailed. Still has a rip in the drivers seat. IO would like to get that fixed some how.
The trans fluid looks new. Hopefully the trans was replaced not to long ago.
I think so far we have about $1600 into it and time.
Old Mar 31, 2014 | 06:50 AM
Old Apr 2, 2014 | 10:50 AM
2 Go Snake's Avatar
Smile
You are really moving along quickly on your engine rebuild. The 4.7 liter is a fabulous engine. I have the 4.7 liter in my 2000 Jeep GC and it pulls really well. I have 198000 miles on it and it runs like a new engine. Once you have the engine rebuilt, I do not think you will want to get rid of your GC. You will be amazed at how well the 4.7 liter engine performs.
Old Apr 16, 2014 | 01:54 PM
crank, pistons, oil pan and oil pump all in the block. Have to finish up lapping the valves on one head. That as soon as my partner/son finishes cleaning it. Also waiting on a timing gear kit. Should be to my door soon.
Old Jun 15, 2014 | 11:39 PM
2 Go Snake's Avatar
Question
It has been 2 months since your last progress report on your Jeep GC. How are things going ?
Old Jun 16, 2014 | 07:24 AM
I've been slacking a bit. I got it all back together turned the key and bent 4 valves on the drivers side head.
I was a little off on the timing chain setup. I talked to a mopar tech and he said the guys hate it when they have to do these. He said it just ruins their day because this setup is so stupid and has been discontinued. Anyway its almost back together and I'm very sure its back the right way. Man I started this in March but I only have about 40 hours into this entire project. I picked up an 04 Mazda 6 that needed some work and is up for sale now so that took some time.
I didn't think anyone was paying attention to this thread so I stopped adding to it. I guess I should add that I have done many different timing chain setups without fail in the past. V-4 Motorcycle's as well several cars.
Old Jun 16, 2014 | 07:35 AM
There's that Chrysler design stuff that I don't miss.
Had the 6 cyl in my GC. **** thing was bulletproof.
Old Jun 16, 2014 | 03:21 PM
mcrider's Avatar
Hey, most of us are gear heads. We love this kind of stuff!
