electric Lambo?????
electric Lambo?????
Anyone seen this???
http://www.lambocars.com/images/lamb...concept01.html
Fabulous design, almost looks like an updates Gallardo, with some tribute to the original Countach thrown in. Skip the electrics and gimme a V10 or V12...
I came up with some wallpapers in different colors, just let me upload them for you. I have two screens so I put the front view on one screen, the rear view on the other.
To be honest, the design looks like a conventional gasoline powered vehicle. All the vents, scoops, etc. for brake cooler, oil coolers, radiators and vents to let out heat and trapped in air are usually for gas powered cars. Electrics don't require all those vents and scoops.
So if it were petrol based, where would the exhaust exit? Tougher question than you think. There are so many places the combo pic looks confusing!
However, if you can see the video link, it shows each configuration as it cycles thru them. (you will need quicktime on your computer to play the clip)
http://home.comcast.net/~thevman2/ex...figuration.mov
However, if you can see the video link, it shows each configuration as it cycles thru them. (you will need quicktime on your computer to play the clip)http://home.comcast.net/~thevman2/ex...figuration.mov
redrock35
05-09 Exterior Modifications
Jul 31, 2016 08:50 PM
