Camless gasoline engine technology
Seems they would use this technology only on a free running engine, not an interference one. At first at least. A hiccup in the electronics causing a valve crash would not be a cheap experience.
Needs to be more Astony
I always liked this system... not having to worry about all the computerized electrical stuff and still see similar gains..
Coates Rotary Valve System
For instance: a static test of a five-litre poppet valve engine on an airflow machine produced a reading of 133 cubic feet per minute (CFM) with valve fully opened. The five-litre Coates Spherical Rotary Valve Engine on the same machine, however, produced a reading of 319 CFMs fully opened; a colossal advantage in airflow comparison. A five-litre poppet vavle engine tested on a dynomometer under the same loads and conditions at 5500 produced 480 BHP and 454 foot pounds of torque. The maximum RPMs on the poppet valve engine were 5700 RPMs; the Spherical Rotary Valve Engine in comparison reached 14,850 RPM's
Originally posted by Knight@October 15, 2005, 3:05 PM
The valve, spring, and all the indutries that make valve train probabaly had somthing to do with not making it happen.
Rotary valvetrains have been around for a very long time (since the first IC engines).
I'm guessing the longevity of the system isn't as great as they allude to. I know they say they ran it through durability tests, but something just doesn't add up. I suspect seals wear relatively quickly and there's leakage issues.
The electronic poppet valves have much more potential.
1 Post
nice idea in theory. I do not imagine any reason why they cannot manage it technically. As for acceptance, I am already getting a little wary that computers now have too much input in an engine. I loved the days when you could take a spanner to your car and fix it!
