2013 Auto Transmission Downshift Bump.
Old Sep 21, 2014 | 10:45 AM
JohnnyMustang2's Avatar
I experience a hard downshift bump just before coming to a complete stop and it does not happen all the time. Its also felt if I put the car in neutral and glide to a stop, the bump travels through the driveshaft and is heard from the rear I recently check with a Ford dealer and they have no tech bullentins addressing this problem, I know i'm not the only one experiencing this. Has anyone with this problem had it fixed by the Ford Dealer.
Old Sep 21, 2014 | 01:47 PM
=HYPERDRIVE='s Avatar
I only had same thing happen when downshifting from 3rd to 2nd gear.
Its rare, but it only happens between those 2 gears. Specially when coasting towards a STOP sign, where I might not stop completely and just slowly roll through it, with little momentum.
I think it might be related on the RPM at the given time you downshift on the automatic, but I think I had it "bump" from 3rd to 2nd even on a full stop maybe couple times, so I dont know.
Old Sep 21, 2014 | 05:42 PM
The idle i think is to high contributing to the downshift jerk/bump. The dealer said the idle was fine and that they cannot adjust it. Ford needs to address this problem on a big scale.
Old Sep 22, 2014 | 10:39 AM
CiniZter's Avatar
are you running on stock tune.
Old Sep 22, 2014 | 10:48 AM
Yes, it's all stock. V-6 Performance Package.
Gigantor
May 11, 2023 07:31 PM
Rando
Aug 25, 2021 11:12 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
