Wont start after a night out..
Well got a problem starting my stang..
Backed it out of the garage and it were outside over the night. The temperature got below zero.
Next day when I were going to drive it back inside nothing happened..
The start engine are not trying to fire but the gas pump is whirring...
What I checked so far..
Got gas..
Battery is charged
Could the cold have done something?
Got gas..
Battery is charged
Received 1,528 Likes
First guess would be a weak battery. Even though it appears to be charged, the cold can knock it down enough that it won't start the car. You could try jumper cables or a starter/charger if you have one available.
Next guess is something froze; but that is not likely and I have left a wet car sitting overnight to freeze many times and it still started up in the morning.
That's not a whole lot to go off of... So starter is engaging and the engine is turning over? Does the exhaust pipe smell like gas? pulling a spark plug is always a scary thing on 05-07 4.6Ls, otherwise I'd say pull some plugs and see if they're getting spark or if they're wet
If the starter doesn't turn over at all, check the relay. Grab the one right next to it, it's for the high speed fan, and see if it's the relay. If the starter still doesn't turn over it maybe the same problem I had, which was the circuit board for the relays was bad and I had to replace the box.
I'd say yep, it's the battery. Cold weather is tough on a battery. Sounds so weak it won't engage the starter, so your just getting a clicking noise. If it's past 4 years old it's time to replace. If it's not you may have a dead cell causing the problem. Either way I'd say garb you a new battery, and you should be fine. Good luck.
Yeah very likely the battery but you could try rapping a screwdriver handle on the starter. I had a dying starter on am older car of mine and that would do the trick, at least sometimes
No, the "starter ain't engaging" and nothing from the engine. Only the gas pump.[/QUOTE]
It's hard to understand for sure what he's saying, but it sounds like the starter isn't turning over at all? If so, then like I said could be the relay.
wanted33 (11/17/17)
Thanks for all the replies.
Finally had the time to check the car.
Tried to change battery, no effect.
Checked all circuits and relays.
Checked for faults with the OBD, no result there either.
Also linked to a video I uploaded on vimeo what happens when I turn the key, because there have been some confusion about my explanations.
OK, if it's not the relay itself, it could be a bad board on the relay box. I was having the same thing happen and it turned out to be the board in the box was bad. If you've determined the starter isn't getting any voltage and all the wiring and ignition switch is OK, there's a good chance you have the same problem. Steeda said the boards going bad is a known problem, and once they replaced mine I haven't had it happen again. Almost forgot, you also need to check the switch on the clutch. You can disconnect it and put a shunt across the pins in the connector and see if it starts.
If you have a manual transmission check the clutch pedal position switch. If you have an automatic check the digital transmission range sensor {DTR}. If automatic have you tried starting in Neutral?
You should also check the wiring at the starter. A lot of corrosion goes on down there.
Both scenarios would result in total silence when trying to turn the key to start it (just not sure about the fuel pump priming, I think that happens regardless, when the key is turned to the ON position)
EDIT:
And it's not a PATS issue, since in the video that Theft light is not misbehaving, it goes out and stays out, when turning the key.
If there was an issue, it would be flashing when trying to start the car
