Where/how to get a wire from engine bay to passenger compartment??
I'm trying to run a wire from the engine compartment through the fire wall to a switch I'm placing under the dash....can anybody help??
Just aft of each front wheel liner is a passthrough grommet that the main wiring loom goes through. There is an additional "nipple" that you an pierce and pass through any wire up to an 8 gauge cable. You must remove the front wheel and both front and rear wheelhouse liners to acess.
You do not have to remove the wheel, but you do have to remove the fender well linings and I you can run much bigger than 8 ga through them. I ran 1/0 ga Power wire for my audio system through that same hole
Mr. Sparkle
9/11/15 02:57 PM
