What is this? Something to worry about?
Old Jul 1, 2008 | 04:55 PM
jmanpatsfan's Avatar
It appears to be some sort of buildup on the throttle body, any ideas? Normal?
Thanks.
Old Jul 1, 2008 | 07:29 PM
aircare84's Avatar
Either you've got hard water & thats just residue from that or the aluminum is corroding.
Aluminum turns to a white powder when it corrodes.
See if you can remove/scrape off. If so, I'd guess it's just hard water residue. Our water here is the pits.
Haven't noticed it on mine, but with the Shaker, I can't see much of the throttle body anymore.
Old Jul 2, 2008 | 03:13 PM
red454's Avatar
Can't tell from your avatar, but do you have a factory hood scoop?
I was at a local car show and a buddy of mine has a new GT/CS and he noticed a pool of water in the same spot on the TB. Figured out it was coming from one of the bolt holes used to secure the factory hood scoop. Sealed it up (silicone) and that stopped the water leak...
Old Jul 2, 2008 | 04:10 PM
Yes I do have the factory scoop.
Old Jul 2, 2008 | 05:00 PM
PolkThug's Avatar
It looks like at some point in time a little antifreeze got up there.
Old Jul 3, 2008 | 08:23 AM
06GT4RAD's Avatar
It looks like corrosion from salty water. That's the type of corrosion I use to get opn certain parts of my fishing boat.
Old Jul 3, 2008 | 01:28 PM
cave diver's Avatar
I had the same thing happen and yours also is most likely from a little bit of water coming in through the factory hood scoop and settling there. It will react with the aluminum, especially with the engine heat, and cause that corrosion. I cleaned mine up with a small SS brush, taped everything up and painted the whole TB with cast aluminum rattle can paint. No problems since because the paint protects the aluminum
unnoticedtrails
Jul 17, 2017 11:10 AM
Feb 10, 2017 07:12 PM
Mr. V
Dec 24, 2016 02:57 PM
FromZto5
75
Oct 5, 2015 02:27 PM
TMDM
Sep 24, 2015 07:00 PM
