Vert top motor problem
Less than 3000 miles and I will need to call the dealer Monday as the convertible top on my 2005 GT convertible will barely close. It sounds terrible! This came on all of a sudden this weekend.
Anyone else have this problem? What ended up being the issue? How long did it take to fix? Yuck!
I appreciate any responses for this problem.
[attachmentid=36296]
Originally posted by dleal00@October 15, 2005, 11:21 PM
My problem is it stops just short of closing fully. Then I let go of the button then push it again and it closes fully. Seems like it runs out of juice when it gets close to closing. Thought it was normal.
Mine did that the first couple days I had it. Had to let off the button and repush it threee times before the top eventually went all the way up. It eventually worked itself out on its own.
Not the problem I am having. When I try to close the top it barely makes it closed. It takes about a minute and the motor is straining to even close it. It has a major problem and I was wondering if anyone else has had this problem. I am not talking about where it closes perfectly except for the last two inches or so.
Thanks.
Thanks.
Originally posted by silverGTvert@October 16, 2005, 5:37 PM
mine will just about close all the way, so i let off the switch, pull it closed a little more repress the switch and it works fine.
I had trouble putting my top up one day.
Then I remembered taking the boot off might help.
I can share this story knowing that no one here at TMS would even think of giving me grief for it!
i`ll give you a little.....
I took it to the dealer and they figured out the hydraulic tank behind the rear seat did not have the plug on it! It had been left off at the factory probably after filling the reservoir.
They cleaned up the mess filled, the tank and it now works as good as new. Just in case someone else experiences similar problems, check back there first.
Thanks.
[attachmentid=36661]
Thanks.
