Vert top motor problem
Old Oct 15, 2005 | 10:24 PM
R67Coop's Avatar
Less than 3000 miles and I will need to call the dealer Monday as the convertible top on my 2005 GT convertible will barely close. It sounds terrible! This came on all of a sudden this weekend.
Anyone else have this problem? What ended up being the issue? How long did it take to fix? Yuck!
I appreciate any responses for this problem.
[attachmentid=36296]
Old Oct 15, 2005 | 11:18 PM
dleal00's Avatar
My problem is it stops just short of closing fully. Then I let go of the button then push it again and it closes fully. Seems like it runs out of juice when it gets close to closing. Thought it was normal.
Old Oct 16, 2005 | 08:14 AM
Sandyman's Avatar
mine operates the same way. One little push when it quits and it settles in perfect.
Old Oct 16, 2005 | 11:52 AM
6505pony's Avatar
Mine did that the first couple days I had it. Had to let off the button and repush it threee times before the top eventually went all the way up. It eventually worked itself out on its own.
Old Oct 16, 2005 | 05:37 PM
R67Coop's Avatar
Not the problem I am having. When I try to close the top it barely makes it closed. It takes about a minute and the motor is straining to even close it. It has a major problem and I was wondering if anyone else has had this problem. I am not talking about where it closes perfectly except for the last two inches or so.
Thanks.
Old Oct 16, 2005 | 05:41 PM
korinwoodo's Avatar
Thats kinda sketchy. I would be really pissed if my brand new car did that.
Old Oct 16, 2005 | 06:34 PM
silverGTvert's Avatar
mine will just about close all the way, so i let off the switch, pull it closed a little more repress the switch and it works fine.
Old Oct 16, 2005 | 07:11 PM
dleal00's Avatar
Exactly what I do. Now why wouldn't Ford have them close all the way without having to repress the button?
Old Oct 16, 2005 | 08:26 PM
Boltzman's Avatar
Good thing its under warranty.take that sucker in!!
Old Oct 17, 2005 | 06:56 AM
WIZARD's Avatar
It sounds like there is something wrong with the motor. Mine takes about 14 seconds to close. Take it to the dealer. Let us know what the outcome was for future info.
Old Oct 17, 2005 | 02:57 PM
Paris MkVI's Avatar
I had trouble putting my top up one day.
Then I remembered taking the boot off might help.
I can share this story knowing that no one here at TMS would even think of giving me grief for it!
Old Oct 17, 2005 | 03:38 PM
WERKED 66's Avatar
i`ll give you a little.....
Old Oct 17, 2005 | 09:30 PM
Boltzman's Avatar
For shame.For shame :nono: JUST KIDDING
Old Oct 20, 2005 | 10:52 PM
R67Coop's Avatar
I took it to the dealer and they figured out the hydraulic tank behind the rear seat did not have the plug on it! It had been left off at the factory probably after filling the reservoir.
They cleaned up the mess filled, the tank and it now works as good as new. Just in case someone else experiences similar problems, check back there first.
Thanks.
[attachmentid=36661]
Old Oct 21, 2005 | 06:58 AM
WIZARD's Avatar
Thanks for the update. As a WB GT Vert owner myself, I was concerned about problems with the top. That is something to keep in mind.
Old Apr 29, 2006 | 06:24 PM
2k5conv's Avatar
Interesting...it's a hydraulic motor? I thought so since I saw tubes and and a tank in my back trunk.
FromZto5
75
Oct 5, 2015 02:27 PM
