Transmission
Old Sep 1, 2006 | 04:15 AM
sts767's Avatar
Transmission
Picked up my car yesterday. It is a 5 speed.
When I shift from 1st to 2nd it makes a small grinding noise. I have found that if I hold the clutch in, pull the gear shift lightly about 1/3 of the way into second I can feel the gears messing and then I can pull it into 2nd with no noise. Takes about a second or so to mesh.
Has anyone else had this, is it because it is new and needs to wear in, or do I need to have this looked at?
Thanks for the help.
Also, intermitently the pass airbag off light comes on and goes off, anyone seen this?
Old Sep 1, 2006 | 04:18 AM
FireFighterHill's Avatar
Take it back.
Old Sep 1, 2006 | 07:41 AM
beat it till the trans falls out. Then get a hole new trans. It may be you just have to get use to it and a little break in.
Old Sep 1, 2006 | 12:58 PM
lodom's Avatar
Do you have anything at all in the passenger seat? If not, the pressure sensor under the seat may be defective. It shouldn't blink on and off.
Old Sep 1, 2006 | 01:54 PM
mrkabc's Avatar
My stick tranny does the same noises when cold and shifting from 1-2. The dealer will tell you this is "normal."
My advice would be to take the car to the dealer when it is cold, the noise will be louder and maybe they will do something about it.
Old Sep 1, 2006 | 06:47 PM
sts767's Avatar
I notice the light is intermittent when I have a passenger only, but it comes on for about 5 -20 seconds once every couple of minutes. Gremlins I guess.
sts767's Avatar
The trany seems to be improving after 120 miles, maybe it will work itself out.
Old Sep 1, 2006 | 09:34 PM
stangster's Avatar
The light sounds like a faulty sensor. Take it in and have it checked out.
CiniZter
25
Apr 28, 2016 05:41 PM
Rando
Sep 30, 2015 12:28 PM
Mustang65bob
Sep 21, 2015 11:30 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
