tires
Old Jan 15, 2008 | 12:02 PM
I-70 west's Avatar
tires
Looking for some feed back on any body using these tires ? http://www.performanceplustire.com/p...-17#prodAnchor
Old Jan 16, 2008 | 12:09 AM
Enfynet's Avatar
I dont think too many run that size, those look like light truck tires.
Old Jan 16, 2008 | 12:31 AM
theedge67's Avatar
Just something to remember, those are H rated tires, which means they are only rated for 130mph. Granted with your V6 you are not likely to ever see that kind of speed, but I don't know what you have planned for the car either. Just something to be mindful of.
Old Jan 16, 2008 | 07:53 AM
SixtySix's Avatar
a 275/50/17 will fit on the rear. If you're going for a staggered fitment, it will work. I run that size, but in a different brand that's V speed rated.
Nitto NT 450's -- 275/50/17 out back, 255/50/17 in front. Car lowered with Eibach springs.
Old Jan 16, 2008 | 01:43 PM
I-70 west's Avatar
That looks good. I want something just a little over the stock 235 55 17s.
and the tire calculator I was using only showed the tire in question. How wide are your rims and how much have you lowered? Would the 275s work all around without lowering on my 8x17 bullits?
Anybody else sized up? show me your stuff.
Old Jan 16, 2008 | 04:34 PM
Stoenr's Avatar
The V6 16" comes with a T rated tire, so at least the move to H is upwards.
But its a move downwards from the pony package/GT stock Z rated. Overkill for the V6 as far as speed ratings go on the V6.
You could go 140 in an H rated tire, just don't hold that speed for long.
Speed ratings are meant for a sustained speed of...........
Don't want the heat build up.
Also note, you said the stock 235/50/17. Stock is 235/55/17, redo your tire size calculator.
Old Jan 17, 2008 | 01:12 AM
I-70 west's Avatar
Yes, 235 55 17 is what I meant. The 255 50 17 is wider but not taller.
I want something between 1/2 to 1 inch in overall diameter than stock.
Old Jan 18, 2008 | 12:38 PM
moosestang's Avatar
How do you like those nittos? They get bad reviews on discounttire.com. I want a taller tire in the rear, but the options are slim to none. Your car looks great with those tires.
Old Jan 18, 2008 | 12:58 PM
SixtySix's Avatar
They do what I want them to do They wear quite quickly, I seem to get about a good 25k out of them before the traction is about gone.
I'd describe them as a good overall performance tire. They feel solid enough on mountain switchbacks, they're not too stiff. I'm overall satisfied with them.
Are there better tires? I'm sure there are, but not in this size and speed rating that I can find anywhere.
For 1-70 West:
These are on 17x9 rims. Don't know if I would want to try the 275's on 17x8's
And these are the diameter you are looking for, but I would NOT run these on the front. I've seen someone who did... it wasn't flattering by any means.
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
