tire psi what to use??????
Old Sep 7, 2007 | 09:25 PM
salsa037's Avatar
got bullets 17 inch with the pirellis p zeero from factory the perilli site says there rated at 51psi does that mean were all supposed to have them a 50 or is that just the max and is 30 to 40 psi good for the tires????
Old Sep 7, 2007 | 11:06 PM
S197 V6's Avatar
51 is the max. do not fill them to 51. check the sticker on the inside of your drivers side door it will tell you what psi to use (on the plastic part that is hidden when the door is closed, just open your door and look around and youll see it). Anywhere between 32 and 35 and you should be good.
Old Sep 8, 2007 | 05:20 AM
Martimus's Avatar
If I recall correctly my door sticker says 35 PSI. Your sticker, however, may be different...
Old Sep 8, 2007 | 06:59 AM
Import-Slaya's Avatar
32 psi at all four corners is what the factory (and your door sticker) recommends.
Old Sep 8, 2007 | 09:12 AM
Falchion's Avatar
Yeah, that's what mine says too. Remember that's COLD pressure. Don't measure it after you've been driving for any distance. Maybe better in the morning, after it's been sitting overnight?
Old Sep 8, 2007 | 10:33 AM
kevinb120's Avatar
I had them on the 06 and ran them at 32 in the summer and 34 in the winter.
Old Sep 9, 2007 | 06:51 AM
metroplex's Avatar
I run mine at 32 and they are wearing very evenly.
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
