Tire pressure sensor
Hey all reacently I changed rims on my 07' GT everything went good except the low tire pressure message still is showing. And yes I have drivin it for more than 2 minutes over 25 mph like the owners manual says to do. How do it fix this?
I had a low tire message and I found that the tire pressure had to have no more than 2 lbs difference, between all four tires. I don't know if that is your problem but...
Are they new or different sensors? the SJB in 07-09's needs to be reset every time you change wheels
edit: need one of these
![](http://carphotos.cardomain.com/ride_images/3/2289/2481/30721240117_large.jpg)
you will have to have the system relearn the sensors like stated. I go through this every spring/fall with my summer& winter wheels on the MKZ. I have ford sensors on the winter wheels but i have to use the tool to relearn the system, if you need the test sequence let me know I have it.
Hey skunk21 , I like your avatar ... I had a 90 I bought new and sold in early 05 after getting my current one. Here's a couple of pix from the day I sold her ...
Antigini-GT/CS
10/5/15 09:43 AM
9/8/15 10:45 AM
