Tire pressure sensor
Old Jan 8, 2012 | 01:09 PM
2007 Stang GT's Avatar
Hey all reacently I changed rims on my 07' GT everything went good except the low tire pressure message still is showing. And yes I have drivin it for more than 2 minutes over 25 mph like the owners manual says to do. How do it fix this?
Old Jan 8, 2012 | 01:18 PM
drakefamily2's Avatar
Did the new rims have the sensors in them
Old Jan 8, 2012 | 01:19 PM
Yes they did.
Old Jan 8, 2012 | 02:44 PM
Wander's Avatar
I had a low tire message and I found that the tire pressure had to have no more than 2 lbs difference, between all four tires. I don't know if that is your problem but...
Old Jan 8, 2012 | 03:56 PM
Pete07GT's Avatar
Did you check the tire pressure to ensure it is within the correct psi? What tire, rim, and pressure setup are you running?
Old Jan 8, 2012 | 07:00 PM
cinque35's Avatar
Are they new or different sensors? the SJB in 07-09's needs to be reset every time you change wheels
edit: need one of these
Old Jan 11, 2012 | 05:26 PM
skunk21's Avatar
you will have to have the system relearn the sensors like stated. I go through this every spring/fall with my summer& winter wheels on the MKZ. I have ford sensors on the winter wheels but i have to use the tool to relearn the system, if you need the test sequence let me know I have it.
Old Jan 12, 2012 | 05:38 AM
05YellowGT's Avatar
Hey skunk21 , I like your avatar ... I had a 90 I bought new and sold in early 05 after getting my current one. Here's a couple of pix from the day I sold her ...
Attached Thumbnails Tire pressure sensor-mustang90.jpg   Tire pressure sensor-mustang90-2-.jpg
Old Jan 12, 2012 | 06:31 AM
skunk21's Avatar
Nice. I like the cobra rear bumper, I almost went that route when I redid mine but I decided to keep her stock looking. you know you will get the fox itch again, we all do
Old Jan 15, 2012 | 06:22 AM
Scrape's Avatar
Tell me about it. I have that itch too.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
oldnjguy
Sep 10, 2015 02:39 PM
Sep 8, 2015 10:45 AM
