tire pressure?
tire pressure?
I just put my 18 inch rims back on the car and I need to know what tire pressure to put the tires at. The rims/tires are 255/45/18, and on the sidewall it says Max Tire Pressure of 51 psi. Should I run them at 51 psi for everyday driving? Thanks!
NOOOOOOOOOOOOO!!!! Do NOT run 51 psi. 17"s are running 32 psi. I think that 18"s are generally running 34-35 psi, but I'm not 100% certain. It's definitely not 51 psi.
I was thinking that 51 sounded too high which is why I wanted to double check. By the way the tires are the BF Goodrich KDW2's, if it matters.
I have Nittos in the same size; 255/45/18. The Max PSI on the sidewall is 50. I run 34-35 psi.
The rule of thumb I've seen is 0-3 psi higher for a Plus-one or Plus-two fitment. I had 17's on the car stock and the door sticker said 32 psi. I started at 36 psi and worked down to about 34.
Greg
Greg
Rando
Aug 25, 2021 11:12 AM
