tire pressure?
Old Mar 11, 2007 | 05:06 PM
S197 V6's Avatar
tire pressure?
I just put my 18 inch rims back on the car and I need to know what tire pressure to put the tires at. The rims/tires are 255/45/18, and on the sidewall it says Max Tire Pressure of 51 psi. Should I run them at 51 psi for everyday driving? Thanks!
Old Mar 11, 2007 | 05:19 PM
SteelTownStang's Avatar
NOOOOOOOOOOOOO!!!! Do NOT run 51 psi. 17"s are running 32 psi. I think that 18"s are generally running 34-35 psi, but I'm not 100% certain. It's definitely not 51 psi.
Old Mar 11, 2007 | 05:22 PM
S197 V6's Avatar
Originally Posted by SteelTownStang
NOOOOOOOOOOOOO!!!! Do NOT run 51 psi. 17"s are running 32 psi. I think that 18"s are generally running 35 psi, but I'm not 100% certain. It's definitely not 51 psi.
I was thinking that 51 sounded too high which is why I wanted to double check. By the way the tires are the BF Goodrich KDW2's, if it matters.
Old Mar 11, 2007 | 05:29 PM
Yeah, 51 psi is the maximum tire pressure rating for the tire. I'm sure that someone with 18"s will soon chime in, but I'm pretty sure that it's 34-35 psi. Sounds like you got a set of good tires there...
Old Mar 11, 2007 | 06:20 PM
karman's Avatar
I have stock 18" wheels.
The label reads 32psi. for the 235 tires.
Old Mar 11, 2007 | 08:34 PM
GregS2005GT's Avatar
I have Nittos in the same size; 255/45/18. The Max PSI on the sidewall is 50. I run 34-35 psi.
The rule of thumb I've seen is 0-3 psi higher for a Plus-one or Plus-two fitment. I had 17's on the car stock and the door sticker said 32 psi. I started at 36 psi and worked down to about 34.
Greg
Old Mar 11, 2007 | 08:39 PM
fordboy97f150's Avatar
i run 34-35 and i havent seen unusual wear, so im guessing thats good
Old Mar 11, 2007 | 08:44 PM
S197 V6's Avatar
Ok thanks for all the help guys! I filled them up to 35 psi, so I geuss i should be good now. Thanks again!
Old Mar 12, 2007 | 04:53 AM
metroplex's Avatar
Tirerack actually recommends the tire pressure on your door sticker regardless of the type of tires.
Old Mar 12, 2007 | 05:42 AM
Mark S.'s Avatar
metroplex is right...check the sticker on your door jamb...
Old Mar 12, 2007 | 09:47 AM
Phorty's Avatar
So does someone running 20's need higher pressure? I never realized this.
Old Mar 12, 2007 | 01:13 PM
hk2006's Avatar
+1, use 32psi as recommended by Ford...
Rando
Aug 25, 2021 11:12 AM
