TCS not working?
Well I live in FL..hurricane dennis feaderbands coming through so lots of rain..thought I would see how tcs works. found dead end road and left tcs on..stomped on it from a stop and spun some tires but didn't seem like tcs came on. No light or nothing! isn't there supposed to be a light that flashes when tcs is engaged? I did it with bot tcs on and off to see if it was reversed somehow but no light? Do you think my tcs is broken? I did the systems check and everything was ok.
I would think that since all systems checked out when you ran the test then it's probably fine, but you could always check with the dealer to make sure.
It won't come on until the car starts to slide sideways, it will let you have plenty of wheelspin in a straight line. Try it in a corner and you will feel it. You have to really let it slip to see the "trac control active" in the display...
My understanding is that it's purposely designed to "ignore" wheelspin in a straight-line scenario (if both rear wheels are spinning at the same speed). This also explains why the TCS is useless if you get stuck in the snow and are trying to go straight forward.
If you're turning, you'll definitely feel (and hear) the TCS come on.
if you have the non IUP, then there is a blinking light that comes on, if you have the IUP, it'll only display "traction control active" in the message center.....
My traction control seems to be very lenient also. I've only seen it come on once, after driving through a wet parking lot and then turning onto the boulevard, but I wasn't even on it and there was no wheelspin, so go figure? Other times when I've been on it pretty hard turning, or in the rain, it hasn't come on at all, when it seems like it definitely should have.
You'll def know at least when the ABS is working. The pedal crunches and pulses your foot. One time I was heading down a hill 2 winters ago in my old car and one vehicle was stuck in the snow. I hit the brakes too hard and the pedal started pulsing and then a patch of ice so when I turned the wheel I kept going straight toward the vehicle. I laid on the horn and the guy saw me coming and somehow moved out of the way as he was stuck. Needless to say I had some sweaty palms and a forehead.
Matt
Matt
Yes, this is a VERY leniant TC.
It does a LOT more than let you spin in a straight line. Ford claimed that's what the previous generation was supposed to do also, but it didn't. It was WAY too sensitive.
I believe they tried to correct the problem and took it too far. While taking a 90* turn in a parking lot, (I was doing this on purpose) I gave the car some gas and was able to whip the car around; then back and forth, leaving a complete "S" black mark WITH the TC on. I had to get out of the gas myself to straighten it back out because the TC certainly wasn't going to.
If this car had any low end torque at all, it would be as dangerous as a 5.0L Fox body. Luckily(?), it doesn't... not even close.
Is this TC normal? NO. Most TC systems are not this bad. Others would actually have a chance of preventing an accident. This one doesn't. The ABS on the other hand is pretty good.
As for the light, what Maverick said is correct. Definitely one dissadvantage to having IUP. The little "note" in the message center is useless. It doesn't get your attention at all.
Hey - where are you at? I was out last night with some friends and let the back end get a little squirrely in a few corners - wooo-hoo!
I live in ellenton..I went to the gym today. there were no cars when I was merging on the interstate so I gave some gas out of the turn..It was raining..I fishtailed and the TCS didnt' come on. i guess tcs if REALLY lenient. I guess I should just leave it on instead of turning it off when I get in my car cause of how lenient it is.
Originally posted by 94tbird@July 10, 2005, 7:29 AM
personally i hate the ABS brakes. I have a 94tbird and when i hit the brakes the car stops on a dime. I had to stop short once in the mustang to avoid hitting someone who for whatever reason had no brake lights working so i slammed on the brakes and abs locked all 4 wheels and the car was still moving foward. IT was slowing down, but nowhere near as fast as my tbird without abs. i barely missed hitting the car where my tbird without brakes woulda stopped me sooner with a squeal of the tires and i would not have been as scared. I wonder if i can disable the ABS in the Stang? Hmm
I've also had a '65, two '88 5.0 LX's and an '03 GT. The only ones that weren't better was the '65. The ABS HAS to be good to compensate for the terrible brakes.
Antigini-GT/CS
10/5/15 09:43 AM
9/24/15 08:15 PM
