Suspension problem???
My 05 GT has developed a suspected suspension problem, here is the symtom.
When going from WOT to coasting and back to WOT in 1st, 2nd or 3rd gear, the car seems to steer a bit, that is I have to make a small steering correction to stay straight (wheels not spinning). I think the axle is shifting forwards and backwards with the torque coming on and off.
I have BMR LCAs and adjustable panhard rod and I also have Eibach pro series springs.
I did a quick check last night and all the nuts seem snug, but tonight (now) I am jacking the car up and taking a serious look.
I do run autocross events, about 6 so far this year so the suspension does get "worked" from time to time.
It is possible the LCA bushings have come loose? Please post any suggestions. I will post my findings in an hour or so.
Problem solved. Turns out the axle was moving. I used an aluminum pipe and lightly pried the axle forwards and backwards on both sides and I was getting some movement from the passenger side. Not alot, but enough I guess.
I noticed there was a fair bit of grease squeezed out along the edge of all the bushings which gave me a clue. I pumped fresh grease into the bushings and now the problem is gone.
I don't remember reading in the instructions how often the bushings had to be regreased or what would happen if you didn't. Anyone out there read or know more on this?
I tore a torque box out of my old 89 5.0 years ago on the highway at 65mph towing a jetski. It had the same (but worse) symptoms just before hte suspension failed and immediately followed by a shower of sparks. Needless to say I was very nervous about my 05 when it started doing the same!!!
Rando
Aug 25, 2021 11:12 AM
