Suggestions on how to remove this?
Old Feb 27, 2011 | 01:32 PM
ajderr2000's Avatar
Does anyone have any ideas on a good way to remove the carmax decal? It isnt a huge problem, just not something I want on there.
Thanks!
Old Feb 27, 2011 | 01:47 PM
antdog's Avatar
Blow dryer, heat it up and peel it off.
Old Feb 27, 2011 | 03:25 PM
mrv8outboard's Avatar
Or you can use a can of compressed air/duster for keyboards and the like. Turn it upside down and it will freeze the adhesive and you can remove it.
Old Feb 27, 2011 | 05:07 PM
Dougxox's Avatar
goo gone works well but just remember to clean and wax it afterwards.
Old Feb 27, 2011 | 05:13 PM
I usually use the hair dryer method followed up with some rubbing alcohol or goo gone to remove the glue
Old Feb 27, 2011 | 06:31 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Hair dryer for me, but I'd like to try that compressed air idea!
Old Feb 27, 2011 | 06:40 PM
chutoyy's Avatar
I say use heatgun on low, or hair dryer, then peel it off with a fingernail or lightly pick at it w/ something similar to a credit card.
Be careful w/ the compressed air can, it may affect the paint (mar/crack the clear coat)
Old Feb 27, 2011 | 07:04 PM
cinque35's Avatar
you don't need any of those things just peal it off
Old Feb 27, 2011 | 11:21 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
You live in Phoenix, the only heat gun you need is an afternoon sitting in the sun. It should come right off. Goo Gone will take care of the rest!
Old Feb 28, 2011 | 09:17 AM
antdog's Avatar
This is true!
Old Feb 28, 2011 | 12:37 PM
ajderr2000's Avatar
So melt it or freeze it... Thanks! I will give em a try. :-)
Old Feb 28, 2011 | 03:28 PM
antdog's Avatar
Don't melt it, just get it warm. If it melts the job becomes much harder.
Old Feb 28, 2011 | 04:01 PM
David Young's Avatar
The decal looks fresh. It should peel off easy.
Old Mar 1, 2011 | 09:39 AM
24FAN's Avatar
Brillo pad will get it off!
Old Mar 1, 2011 | 04:59 PM
1fastbob's Avatar
The Corvette I purchased had a black Carmax sticker on the back. I asked them to remove it and they did. If I were you I would use the hair dryer method followed by WD-40 or Goo Gone to get the residue.
Bob
Old Mar 1, 2011 | 05:59 PM
pilatti1's Avatar
I sprayed mine with WD-40 & then used my wife's hairdryer on low until it began to melt &then just peel it off, then a cleaner wax & finalize with a good coat of your favorite wax.
Good Luck
Old Mar 2, 2011 | 05:04 PM
cbf102770's Avatar
I had them remove it before I pulled off the lot, then hit it with some wax after I got home and washed it. Their cleaning crew sucks lol.. also had some chrome trim around the taillight and 3rd brake light that the effed up removing, left all the foam doubles stick tape behind. Used goo gone and blow dryer follwed by wash n wax....good as new.
Old Mar 2, 2011 | 07:18 PM
tdbrown75's Avatar
3M Wax and Adhesive Remover!
Tim
Old Mar 7, 2011 | 05:56 PM
robair's Avatar
Any sander will take that right off
Hbadger94
Sep 24, 2015 08:16 PM
robjh22
Sep 23, 2015 07:03 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
