Strange thing happened with oil pressure
Well, I got in my stang and turned on the parking lights, then I put in the key and turned it to start but I did not start it. The oil pressure gauge started high then moved all the way to low. That sounds about right because the engine is not running. Then I started the car. The message center blinks "oil pressure low" and the oil gauge turns red and begins to rise. It gets half way and the gauge turns blue again. I don't think there is really an oil pressure problem. But I would feel better if this happened on anyone else's stang also. I would appreciate it if someone could try it and let me know. Thanks.
i would check it out right away..... use a mechanical gauge....
my car does it too sometimes when i start it
I just start the car and it does exactly what you say and then the gauge seems to wake up and the warning goes away. I was going to complain to my dealer about it.
9/8/15 10:45 AM
